How to find a component using Search Filter
Hi, I’m used to using a competitor site’s parametric search to specify components for new designs but I suspect DigiKey will have a greater range of parts to choose from. However I’m having trouble using the Search Filter.
I’ll use finding a power inductor as an example.
I know how to select one or more options from a parametric list, for example I want a 18uH inductance so I select this value option in the Inductance column.
Where it’s offered I know how to select a minimum value. I need at least 200mA with some margin, so in the Current Rating (Amps) column I type 500 in the Min box and select mA from the units dropdown.
But now I need to select a range of saturation current values, and I also want a minimum of 500mA. But in the Current - Saturation (Isat) column there are a great many options, in fact there as of today there are 1,483 options greater than and including 500mA. I can sit here and select them all one at a time, but there is a friendly looking text box at the top of the column marked Search Filter. It’s begging me to type a search term like >500mA or something, but I cannot find any format that works.
How are these Search Filter expression boxes supposed to be used? What is the syntax for the search term? Is there a manual somewhere for this parametric search facility?
Greetings,
Behaviors of the different filter headings vary depending on how the information is stored in the backend database. Things stored as numeric values can offer min/max/unit filter functions, but a “Search Filter” box indicates data stored as text, and only performs a simple string-matching function. Trying to enter an “expression” won’t do much for ya.
Is that less than ideal in many cases? Yes. Changing things is harder than it may seem however.
The workaround is an interface paradigm almost as old as graphic interfaces themselves, known as shift-clicking. Click one value in a column at the end of a range you wish to select, then hold the shift key while clicking the value at the other end. All values in between will also be selected.
A side benefit of this is that it prompts thinking about what one really wants. Yes a person could select all the way to an 80+ amp Isat, but stopping at 5 or 10 if one only needs a half can focus things more quickly.
Not aware of any manual per-se, but there’s probably 150 collective years of use experience monitoring this forum on a given day.
Bonus tip: The “|” character functions as an “or” in the general search box, and is particularly handy for quickly comparing two part numbers, as in this example.
