Many connectors are available for the LAPP Ethernet cables. One of the best ways to match cables and connectors is to consult the tables in LAPP’s Industrial Communication Catalog.
Difficulty:
Student — difficulty levels explained
Last update: 03 Nov 2026
Example Connector Selection
As an example, consider the LAPP type 2170464 PVC jacketed Ethernet cable shown in Figure 1. There are 11 unique connectors as well as a cable to cable coupler as shown in Table 1.
At the time of this writing, there appears to be a preference for the T568B standard. This is based on comparison of the LAPP 21700600 and 21700601. There is a slight cost advantage for the 21700601 (T568B) and twice the available stock at DigiKey.
| Connector | Configuration | T568A | T568B |
| RJ45 plug | Straight, latched | 21700600 | 21700601 |
| RJ45 plug | Straight, cable gland | 21700652 | 21700653 |
| RJ45 plug | Angled, cable gland | 21700636 | 21700637 |
| RJ45 socket | Straight | 21700611 | 21700612 |
| M12 X-coded connector | LAPP part number |
| Straight male plug | 21700602 |
| Straight female socket | 21700621 |
| Female socket, wall mounting/flange | 21700622 |
In addition a type 21700623 coupler is available to join the ends of two cables.
Table 1: Connector options for LAPP 2170464 Ethernet cable.
Figure 1: Lapp Type 2170464 Ethernet Cable being prepared for termination into a RJ45 plug.
Tech Tip: Recall that T568A and T568B differ in their wire color to pin mapping. The distinction matters little for a straight RJ45 to RJ45 cable provided both ends are wired the same. However, pay attention when constructing an RJ45 to M12 X-coded cable (Figure 2). Incorrect assumptions with regards to the A vs B color code may results in a swap of the orange and green pairs. Either A or B RJ45 connectors may be used provided the assembler is aware of the problem.
Figure 2: Color code for the M12 X coded connector.
Locating Connectors from the Catalog Tables
The data for Table 1 were collated from tables in the LAPP catalog. Figures 3 and 4 show the larger matrix used to select connectors for the 2170464 cable. Note that the images occur across a page break. The 2170464 cable is the last row in each image.
Figure 3: Left-hand page for the LAPP Quickfinder Connector table.
Figure 4: Right-hand page for the LAPP Quickfinder Connector table.
