How to order this part D15PG0R1P5BX
------Question for D15PG0R1P5BX Please Put your question below------
I have order D15PG0R1P5BX with some other component from sam manufactor and only D15PG0R1P5BX was cancel by DigiKey.
Because of all component have to use at same time I would like to know how can I order D15PG0R1P5BX and how long for waiting.
Hello thitisuk,
Welcome to the TechForum, I’m sorry, at this time I have no answer to offer. The manufacturer has not given a definitive lead time on the parts.
Thank you for the update, Quinn.
Since the manufacturer hasn’t provided a definitive lead time, could you please clarify if there is a specific reason for the delay or cancellation? (e.g., raw material shortage, production issues, or if the part is being phased out).
Also, do you have any suggestions on where else I might be able to source this part, or are there any recommended alternatives that are currently in stock? This part is critical for my project and I need to find a solution as soon as possible.
@thitisuk
For the alternative option that would work the below link shows the items I had found.
I am sorry to say that these would also not have stock either.
0.1 pF Ceramic Capacitors | Capacitors | DigiKey
I also did not see anyone that would have stock.
As for the reason for the lead time we can submit an inquiry for that to see if they can supply that data.
Unfortunately, we have no stock parts to offer as the link given shows. You might want to verify the requirements for your project and see if you can change a tolerance or something in your specifications to find a part that is more highly available. The parts linked have longer lead times or no information given.
