What do you think? Are there any mistakes in it?
Hi, Mr. Engineer, thank you for your encouragement. It has been a long time since I started a new project. My warmest regards to you, with the utmost respect and appreciation. Dear Engineer.
One thing that stands out is that you want C1 and C2 much physically closer to the pins they’re connected to. Basically as close as possible.
But no problem, the capacitors are close, but their filtering is 100nF.
Thank you very much
Because VDD outputs 3V, it needs to be filtered.
Needs to filter DC output from CP2102 Chip Best capacitor for filtering 100nf
Thank you for the advice. I am with you, Eng Sabry Al Madan.
The output from the CP2102 Chip is a distorted signal that needs to be filtered.
Same voltage regulator
The discussion is very very nice
Thank you dear for the discussion. It is beautiful electronics.
Thank you, dear friends, for the discussion, it is a fruitful discussion
Hi, if you have any other comments, please let me know.
