I need a replacement cap for an MSI motherboard
Hello all,
I just bought a used PC and found that while it was packed well in the shipping box, the sender had neglected to check inside the chassis itself, so the loose CPU heatsink flailed around and knocked a component loose; from what I can figure it’s a capacitor, but I’ve been having trouble finding an exact replacement through googling the exact text on the capacitor.
Can someone help me find a replacement? Physically it’s 6mm in diameter and about 8.7mm tall, and is the type of cap that has two leads trailing through the base to be soldered to the PCB. I’m attaching a pic of the cap in question.
Thanks!
travis.schultz
It is 560UF - 6,3 V
You can buy here:
Holy cow, I don’t know how you managed to track down the exact one to a shop out of Brazil, you’re amazing!
Thanks!
