Motherboard capacitor replacement
Hello, I need help with buying the correct replacement capacitors for an old computer motherboard. I included a picture of both the front and back of both capacitors that I need. If someone can guide me with a direct link to the ones I need, I would really appreciate it. Thank you!
There are literally hundreds of parts in stock that are 1500uF 6.3V+, any one of them will work electrically.
I also added a 5K+ minimum life @ 105° spec to reduce the choices.
Choose one from this list based on diameter, height and lead spacing that fits in the assembly.
Thank you very much! This is my first time ordering capacitors so I wasn’t sure how to properly search for the right ones. I appreciate the info about diameter, height, and lead spacing as well.
