Im working on a home audio system from LG model (OK-99).
I cant seem to find this part anywhere. The pcb board that it is on says it is Q955.
I have included pics of the part which I believe its a transistor with the pins out and pics of the pcb board. Can anyone help identify this part and what its replacement is?
Welcome to the DigiKey TechForum jguerrero_79.
Looking at the top of the 3rd number, I would guess it would be a 4, so the part number may be C5344, but we do not have a match for that number at DigiKey. Take a look and see what you can determine for that number. You can find a lot of info on a google search for that part number.
I have assumed that is a 4 as well and type C5344 into google as well and I always come up short. Asking for help like this was kind of my last resort.
That marking on the pcb is Q955
I would say the part number you have is 2SC5344. I would look at a possible alternative of BC33740BU-ND on this link: BC33740BU onsemi | Discrete Semiconductor Products | DigiKey
It is not as high for the gain maximum rating. It just was the highest I could find. You can review the data sheet to see if you think it will work.
The “C” was commonly used for Japanese transistors with a 2SC prefix, so i agree that it is probably a 2SC5344. This is equivalent to a NTE289. Specs can be found at nteinc.com
