I WANT TO MAKE THIS UPLOADED IMAGE TYPE PRODUCT
PLEASE SUGGEST BEST MODULE FOR MAKING UV LED INK CURING LAMP, also suggest UV light intensity regulator with a display.
Hi arthiveatwork,
Welcome to the TechForum.
We don’t have a single module capable of anywhere near that sort of output, so you would need to build it out of multiple emitters. Here are a few links to take a look at to get you started:
Regarding LED driver power supplies, here is a link to some capable of the kind of power you require. Note that the actual required specs would depend on the configuration of the LED array you create.
