Continuing the discussion from Help Identify Burnt Out Component: I have taken apart a similar 12V (3 Lithium Cell Batteries) replacement pack and photographed what should be the identical component. It is a “KS3080K” but I do not find that component from you by this number? Can you provide a cross reference so I can order this part? Interestingly, this new battery pack has two of these components and the older pack with the burnt out component only had one, but there is a place on the board for two…perhaps this will fix the burning out part issues on recharging the old packs…Let me know if you can find an equivalent part and it’s actual part number. See previous threads for older circuit board layout. Thanks again, Dana
Hello, maybe 353-MCU6D5N06YLQ-TPCT-ND might be suitable replacement. Please look over the specs before ordering.
