Im looking for help identifying the following 3 sets of connectors.
Im looking for both male and female parts.
Thank you in advance.
My Technical reference is T4361865
This one looks like 455-2929-ND (JST # SMR-03V-B) and 455-2925-ND (JST # SMP-03V-BC)
Associated Contacts are listed on each respective housing page.
This one looks like A106290-ND and A112792-ND.
With the associated contacts listed on their pages.
Thank you guys so much!
Any idea on the remaining set?
I do not find a matching part for the other part. does this have any markings ?
The only markings I can find are H JST
I bet the 5 position black connector is from the same JST SM Series.
The plug housing could be SMP-05V-BC and the Receptacle housing would be SMR-05V-B. At the moment the plug would be a noncatalog quote and order. Both parts are subject to factory minimum order quantities as well as factory lead times.
Here’s the SM Datasheet: https://www.jst-mfg.com/product/pdf/eng/eSM.pdf
