Hello, I have a cap, a fuse and a 4 legs transistor
i am looking for, i really cat seem to find correct part number on the site here. I’m sorry i need help.
Capacitor has these markings CT X1 CTX 0.68uF K 300V~
Fuse has an 15 A marking and the board has ST15A/250
The transistor has LT 6203 GBJ 2506
Would it be possible to get the order link to each please if you have available.
Thanks again.
Amazing service!!
Hello @OrangeCircuit,
For the X1 safety cap, possible options are here: https://www.digikey.com/short/8tf1ht7w You can use any of the parts rated 310vac or higher. Please check the dimensions to make sure the part will fit.
For the fuse, i cant see the markings on the fuse cap ends but I would guess this would be fast acting and guessing the dimensions this might be the 1/4" x 1 1/4" fuse size. Possible option F1870-ND. For other variations, dimensions, and response time see link https://www.digikey.com/short/zq927bdv.
For the GBJ2506 bridge, any of the options here https://www.digikey.com/short/qf5209dw
Thank you!
Jeff,
Hi. Can anybody help me to get the part number for this diode? Thanks
Welcome to the DigiKey TechForum Floroff.
I’m sorry, but I did not find a diode with the same markings.
We do not have a way to look up top markings to find the part numbers.
