Hi. I’ve searched everywer. Need help to Identify or find replacement part. I’ts a 8 legged ic, belive it’s some kind of voltage/current regulator. It’s marked 79F1 and next row SSSB. Hope someone can help.
Hi,
Thank you for your inquiry. I am unable to find any cross reference regarding that particular part marking.
Hi gunstedtrobin,
To give us a better chance of identifying it, can you provide some good quality images of this part? Also, dimensions of the body of the part may be useful as well.
In what sort of device is it used?
Actually, I think I found it - LM5085MY. See page 25 of datasheet for part marking.
- LM5085MY/NOPB IC REG CTRLR BUCK 8MSOP
Thanks alot. Seems to be right. Pinout is correct. Component not broken, it’s corrosion. It’s a controllercard to a industrialismen servo motor.
