Identify SOT23-6 IC, marking 2105BCQQ, Inside mains LED driver
I have SOT23-6 SMD IC with markings code 2105BCQQ pdf documan pls
Berk_2
Thank youfor contacting DigiKey , sorry I am not finding anything with those part markings to be able to tell you what this component is or find a data sheet for it .
Thanks Craig
berk_2
You can replace 2105B with full analogs of the following microcircuits:
  1. BP2329A with marking 2329A, Non-isolated Buck APFC Offline LED Controller, from BPS (Bright Power Semiconductor Co.), www.bpsemi.com
  2. WS3410 with marking 3410, Non-isolated Buck APFC Offline LED Driver, from Winsemi, www.winsemi.com.
    2329A - BP2329A.pdf (464,0 КБ)
    3410 - WS3410.pdf (471,9 КБ)
Thank you
I check
You are Welcome! :handshake:
Based on what’s been brought up so far it seems the best option we’d have available is part number NCP1622BECSNT1GOSCT-ND.
Unfortunately I couldn’t confirm the complete specs on the original component, so many thanks to Adam7 for the informed response!
I changed the IC 2329A I bought today and it works without any problems, thank you everyone.
berk_2 Great! :+1:
