I have SOT23-6 SMD IC with markings code A62AF pdf documan pls
Please, photo of this chip.
Check out these two options:
SI9183DT-30-T1-E3 Vishay威世 SI9183DT-30 SI9183 SOT-23 电源管理IC 低压差稳压器图片_高清图_细节图-陈德民-维库仪器仪表网
MM3141ZNRE MM3141ZNRE LDO Voltage Regulator SOT-153/SOT-25A/SOT23-5 marking A6 Short-Circuit Protection Over-Temperature Protection|Welcome to Eric Online Store - Shenzhen ERIC Electronics Co., Ltd.
They are both similar.
On DigiKey:
Thank you so much
You are Welcome. ![]()
Thanks, Adam7, looks like you hit the nail on the head. As a follow up, the SI9183DT-30-T1-E3 is obsolete, but in the previous post’s link you’ll find that there are a number of similar parts available for substitutes. Just make sure the specifications meet your requirements before committing to a purchase for any one item. Thank you!
