I am planning to purchase Times Microwave LMR-195 cable, part number 1946-LMR-195-DS-ND.
My requirement is either of the following:
Two individual spools, each 500 ft (152.4 m) in a single continuous length, or
One continuous 1,000 ft (304.8 m) spool without any splices.
On the product page I noticed the “Spool Size” is listed as 500 ft.
Could you please advise the correct way to enter this order in your system to ensure:
I receive the cable in the continuous lengths specified above, and
There are no unintended splices or multiple shorter reels substituted.
If a note in the purchase order or a specific ordering procedure is required, kindly let me know the exact wording and steps.
Thank you in advance for your guidance.
I look forward to your reply.
When ordering, it would be advised to put in your Web Order Notes a note that indicates 2 full 500ft spools of continuous length wire are required for your order.
Otherwise you can also instruct that to our Customer Direct Representatives over the phone to make a note.
The “spool size” here would indicate the lengths in which the material is ordered from the supplier, and therefore the maximum length Digi-Spool that could be accommodated.
Placing an order for two line items each at qty 500 should yield the desired result, with cart appearing as below.
