Inside diameter of toggle switch extender (AT468C, etc)
I have 1/4" toggle switches and need caps/extenders. I found NKK’s AT468 but there are no dimensions listed for inside diameter. Will these fit?
Where can I find inside diameter dimensions for other extenders?
Thanks for your help!!
Welcome ot the Technical Forum. This really is not listed as an extender. It is just a switch cap. Why you are not seeing any dimensions is they are made to fit on certain series of toggle switches. You will see this for the For use with: A, B and M Series Toggles. This is listed on the website. Though I looked at the data sheet. It is listing the diameter of .197" Here is the link to the data sheet: https://www.nkkswitches.com/pdf/accessorieshardware.pdf
It is on PDF page 10. Unfortunately we just list this type of product as an Accessory. They belong to a certain set of switches. There is no way to narrow down by size only. I do not see diameter listed. You would just have to look at styles and check the data sheets.
