NKK Toggle Switch Boots for M, P, S, WT Series
NKK M, P, S, & WT Series Toggle Switches work with below boots.
Black Silicone Rubber Splashproof Boot Assembly, M12x1 Full Boot 14.8mm Height
AT4181 (360-3019-ND)
Black Nitrile Butadiene Rubber for Oil Resistance, M12x1 Half Boot IP65 - Dust Tight, Oil and Water Resistant 10mm Height
AT401A (360-1605-ND)
Black Silicone Rubber for Flexibility, Resilience, and Tensile Strength over Wide Temperature Range, M12x1 Half Boot Environment Sealed 10mm Height
AT401S (360-2981-ND)
Gray Ethylene Propylene Rubber for Dust & Ozone Resistance, M12x1 Half Boot Dust Proof 10mm Height
AT401H (360-3712-ND)
Boot seats over supplied Hex Nut. Hex Nut tightens O-ring against Panel. Click Here for replacement 12.1mm O-ring AT401P (360-1719-ND).
Click here for all DigiKey Toggle Switches
Click here for all DigiKey Accessories - Boots, Seals
Click here for Source Reference Datasheet (p.7/33; Y8) (p. 32/33; Y33)
