HI to all New at DigiKey, we have a Instrument cluster screen distortion problem, we changed the screen but still the same ! Any help is appreciated.
Hello gte-engineering,
I could not determine what distortion problem you are having from the pictures. (Pictures did not show up on the TechForum).
If it’s not the screen, that it’s in the solder connections or components.
I would have no idea what would be the specific problem. Maybe one of the engineers, that monitor the TechForum, may have some suggestions for troubleshooting your problem.
Hello Geng,
Size dimensions will be needed to help narrow down the options for best fit.
Description: CAPACITOR 470UF 80V
Many options available with these specifications. Please filter this by the physical size you need.
Description: CAPACITOR 220uF 35V surface mount. For the sufrace mounted capacitors will need to verify the land size.
Options: https://www.digikey.com/en/products/filter/aluminum-electrolytic-capacitors/58?s=N4IgjCBcpgnAHLKoDGUBmBDANgZwKYA0IA9lANogAMIAugL7EC0ATMiGpAC4BOArkVIUQAVjqMQTJNA5ReA4mUiUIDCW2UgWLKn3QACAMwiAbvtx8eWFPn0BbEnwB2XcUA
See surface mount land size.
