Filter caps
i am looking for these two caps
Add images
Add images
Hello @mikecasey,
Out of curiosity what type of equipment are you restoring?
Unfortunately, you are unlikely to find a drop-in replacement with these chassis mount dual electrolytic capacitors. Options:
  • Instead, install discrete units inside the chassis.
    2 ea 22 uF type UCY2H220MHD by Nichicon
    2 ea 39 uF typr UCY2H390MHD by Nichicon
  • If you are a purest, and wish to preserve the unit’s look, you may be able to carefully open the capacitor can and install the new units. This takes considerable care and a lathe to open the can without destroying the metal.
Note that capacitors have loose 20 % tolerance. The selected 22 and 39 uF values are generally within this specification.
Best wishes,
P.S. You may want to use terminal strips as a new home for yor capacitors.
Thanks for your email. I am not a purist at all. So I just want to make this 40 year old amp work. So i would like to buy the necessary parts please.
Excellent, @mikecasey!
Please use:
Happy soldering!
Aaron
P.S. Please let us know if you were successful.
I always have a problem with the verification code. Why is this happening. Why can’t I just login.?……
mikecasey,
You can also call us to place an order. The phone number 1-800-344-4539 will get you right to the sales department.
