KO128B2007 vs KO128G2007 | quick connect vs screw terminal?
I have a question about the difference between KO128B vs KO128G. The datasheet does NOT correctly label the difference. I believe it has to do with wether or not the terminals are quick connect or screw terminals. But I have conflicting information. Can you please pull the two parts and let me know which one is quick connect?
Links:
KO128B2007
KO128G2007
Datasheet (does not specify)
So, I do now see that the DigiKey specifications to specify that B is screw terminal and G is quick connect. However, we are ordering this product from another company using the “B” part number and we are getting quick connect. I think that’s where the confusion lies. Can you confirm that G is supposed to be a quick connect?
@JayShoe
I have submitted this inquiry. We will let you know what they say when we hear back.
Thank you for your patience.
KO128B2007 have the screw terminals.
KO128G2007 have the quick connects.
