------Question for 3239-24-1-0500-005-1-TS Please Put your question below------
I’m looking to get a quote for these 2 wires.
2324-3239-BL
CN120L-50-ND WIRE 24 AWG HOOK-UP 11/0.0063 3000V BLUE
2324-3239-YL
CN120Y-50-ND WIRE 24 AWG HOOK-UP 11/0.0063 3000V YELLOW
Please quote for 1000 feet of both. Would like to get in either 1-1k spool or 2-500 ft spools.
Thank you for contacting DigiKey’s Technical Support department and welcome to the TechForum. Technical Support cannot assist with quote requests.
You can generate a quote from our website using the myLists tool. Or if you prefer, you can send your request to quotes@digikey.com.
Best regards,
Jon
For quoting you can use the myLists tool. You will have to be logged into to create a list and then generate a quote.
The part numbers that you provided are only for the 50ft spools. Below are the part numbers for the 500ft spools, which is the standard packaging for these spools.
CN120L-500-ND - HOOK-UP STRND 24AWG BLUE
CN120Y-500-ND - HOOK-UP STRND 24AWG YEL
