Latching = push-push switch?
is the TL2285EE switch which is specified as an on-on (latching??) a push-push
switch so that a push latches it down with appropriate connections and a
second push “unlatches” it (i.e. it is not a momentary switch)?
Greetings,
Per the datasheet, the “EE” in the part number specifies a latching function, which generally does indicate the sort of push-push function you refer to.
Thanks.
That’s what I thought. Got a couple on order and will confirm.
Received some of the switches … just confirming that latching does indeed equate to “push-push” (i.e. first push latches the button down with its associated connections, and a second push “unlatches” the switch and it returns the button to the up position).
