The purpose of this demo using the Lattice ICE40 FPGA UltraPlus Breakout Board.
is to show using a finite state machine how to write to the internal FPGA SPRAM using the internal FPGA SB_SPRAM256KA module shown below,
The next verilog HDL was used in this demo,
//Digikey Coffee Cup test of the SPRAM, using a state machine to write values in SPRAM, then
//reading them. The values written in memory is different combinations colors of a RGB led
module top(input clk, output LED_R, output LED_G, output LED_B);
reg [7:0] state;
reg [31:0] counter;
//access to spram
reg [15:0] ram_addr;
wire [15:0] ram_data_in;
wire [15:0] ram_data_out;
wire ram_wren;
parameter IDLE = 0, INIT0 = IDLE+1, INIT1=INIT0+1, INIT2=INIT1+1, INIT3=INIT2+1, INIT4=INIT3+1, INIT5=INIT4+1, INIT6=INIT5+1, INIT7=INIT6+1, RUN=INIT7+1;
reg [2:0] led;
//leds are active low
assign LED_R = ~led[0];
assign LED_G = ~led[1];
assign LED_B = ~led[2];
SB_SPRAM256KA spram
.ADDRESS(ram_addr),
.DATAIN(ram_data_in),
.MASKWREN({ram_wren, ram_wren, ram_wren, ram_wren}),
.WREN(ram_wren),
.CHIPSELECT(1'b1),
.CLOCK(clk),
.STANDBY(1'b0),
.SLEEP(1'b0),
.POWEROFF(1'b1),
.DATAOUT(ram_data_out)
initial begin
state <= INIT0;
led <= 3'b000;
counter <= 0;
end
always @(posedge clk)
begin
ram_wren <= 1'b0;
case(state)
IDLE:
begin
end
INIT0:
begin
ram_addr <= 16'b000;
ram_data_in <= 16'b001; //write red
ram_wren <= 1'b1;
state <= INIT1;
end
INIT1:
begin
ram_addr <= 16'b001;
ram_data_in <= 16'b010; //write green
ram_wren <= 1'b1;
state <= INIT2;
end
INIT2:
begin
ram_addr <= 16'b010;
ram_data_in <= 16'b011; //write yellow
ram_wren <= 1'b1;
state <= INIT3;
end
INIT3:
begin
ram_addr <= 16'b011;
ram_data_in <= 16'b100; //write blue
ram_wren <= 1'b1;
state <= INIT4;
end
INIT4:
begin
ram_addr <= 16'b100;
ram_data_in <= 16'b101; //write pink
ram_wren <= 1'b1;
state <= INIT5;
end
INIT5:
begin
ram_addr <= 16'b101;
ram_data_in <= 16'b110; //write light blue
ram_wren <= 1'b1;
state <= INIT6;
end
INIT6:
begin
ram_addr <= 16'b110;
ram_data_in <= 16'b111; //write light pink
ram_wren <= 1'b1;
state <= INIT7;
end
INIT7:
begin
ram_addr <= 16'b111;
ram_wren <= 1'b1;
state <= RUN;
end
RUN:
begin
counter <= counter + 1;
//increment address every ~1sec at 12Mhz
if(counter == 32'h1000000) begin
ram_addr[2:0] <= ram_addr[2:0] + 1;
end
if(counter == 32'h1000002) begin //wait two cycles to have data
led <= ram_data_out[2:0];
counter <= 0;
end
end
endcase
end
endmodule
A finite state machine was used in this demo to write values in SPRAM module, then reading them back. The values written in memory consist of different combinations colos of a RGB LED in the platform. The colors written to the SPRAM module were RED, GREEN, YELLOW, BLUE, PINK, LIGHT BLUE, LIGHT PINK, YELLOW in that particular order. Then these colors were read from the SPRAM module and displayed in the RGB led in the board.
After the module was synthesized with the tools outlined in previous articles like this one. The following video shows this SPRAM module demo,
The Lattice ICE40 FPGA UltraPlus Breakout Board is an excellent FPGA board for many applications and is available at DigiKey. Have a nice day!
This article is available in spanish here.
Este articulo esta disponible en español aquí.
