Layer Stack for DKRed 4 layer
Support,
What is the layer stack for the 0.062" 1 oz copper. I am needing to make Single Ended traces at 50 ohms and Differential Signals at 100 ohm. I am needing the standard way the DKRed Board house assembles the layers so I can input their value into my trace width calculator. I would need the Dielectric Constant, material height and filler height.
Thanks,
Lance Robbins
Hello @lance.robbins,
Thank you for your post.
I would suggest checking out the DKRed page.
DKRed | DigiKey
They also have their own subgroup on the forum for questions like this :
DKRed: An extension of DigiKey’s PCB Builder - Design Tools and Resources / DKRed and PCB Builder - DigiKey TechForum - An Electronic Component and Engineering Solution Forum
Thanks,
I found the PDF for the 4 layer PCB. It should have all of the information.
For those reading along the DKRed service information can be found here under > Specifications > 4 layer stackup document
That is also where you will find the 2 layer stackup document.
