Learning Companion for the Resistive Current Divider
This page is a learning companion, not a tutorial.
This learning companion supports the canonical Current Divider article and its worked examples.
Purpose of this document
These questions may be assigned:
  • as homework
  • an interactive group discussion
Audience Key
The following emojis are used to classify each question with alignment to Bloom’s taxonomy:
  • :hammer_and_wrench: Technicians – Factual, practical, and troubleshooting-focused
  • :graduation_cap: Students – Foundational understanding with basic application
  • :test_tube: Capstone students and field engineers – Open-ended analysis with emphasis on system-level design tradeoffs
  • :red_apple: Teacher – Topics suited for discussion groups or guided exploration
1) Present the two recommended forms of the current divider equations. :graduation_cap:
Answer found directly in canonical article.
2) Present and then solve example problems for each equation. :graduation_cap:
Be sure to include examples involving multiple resistors. Be sure to work the problem backwards looking for the resistance given a desired supply and branch current.
Tech Tip: This question requires active learning where you frame the material, provide a solution, and then verify that the solution is correct. Lean into it and work with a classmate to see who can come up with the best questions.
3) What is the current divider equation? :graduation_cap:
Answer
4) What are the properties of an ideal constant current source? :graduation_cap:
Answer
5) Show the algebraic steps to convert the general current divider equation into a two-resistor solution for I_{R_2}. :graduation_cap:
6) Given a parallel circuit consisting of 4 components, solve for R2 given the R2 branch current of 5A: :graduation_cap: :red_apple:
  • 15 A constant current source
  • R1 = 2 Ω
  • R2 = unknown
  • R3 = 4 Ω
Answer
7) Contrast and compare the current divider equations and the voltage divider equations. :graduation_cap: :red_apple:
Hint: Construct a table showing the resistor pair equations as well as the multi resistor equations. Look for patterns that will help you remember all of the equations.
8) There is a tension in this article with regards to the “error prone equation.” :graduation_cap: :test_tube: :red_apple:
Describe the reasoning for the author’s apprehension. Do you personally agree with the author? Where is the point of confusion and how can it be avoided?
9) What is a Thévenin equivalent circuit? :test_tube: :red_apple:
How could it be used to simplify Figure 1 especially when solving for the R3 branch current.
10) What passive electrical component has constant current properties? :test_tube:
Hint: The comparison is transient and only applicable for the moment the device is turned off.
:writing_hand: Article by Aaron Dahlen, LCDR USCG (Ret.), Application Engineer at DigiKey. Author bio.
