LED Life span
------Question for CUN66A1B Please Put your question below------
Hi DigiKey.
Do you have an data for the average lifespan of these LEDs please?
Best Regardsm
Andrew.
Greetings,
The datasheet on page 16 mentions some information along these lines, though the construct of the information may not be entirely of the sort you seek.
Since devices of the type often degrade in function over time more so than failing abruptly and catastrophically as an incandescent lamp might, the answers to such questions can vary quite a bit depending on how one defines “failure” for purposes of the application. Actual numbers will vary substantially in any case with application conditions, device temperature usually chief among them.
Note that the failure criteria they use on page 16 specifies failure as either an increase of 1.2x the initial Vf value or a reduction in radiant flux to 0.7x the initial value.
Also note that their test merely states that none of the 10 samples “failed” as specified above over a 1000hr period. It states nothing about how long beyond this time one might actually expect it to fail.
What really matters in maintaining a long life is temperature control. In all cases, the cooler the part is kept while in operation, the longer it will last. The datasheet specifies that the max operating temperature for this part is 85ºC. However, I would not recommend operating it anywhere near this temperature if you want it to last. The generally accepted rule of thumb is that for every 10ºC warmer that an LED is operated, the lifetime is halved. So, the relative life can be approximated as follows:
Typical LED lifetime relative to life at maximum operating temperature:
  • 85ºC → Minimum lifetime = Lmin
  • 75ºC → 2 x Lmin
  • 65ºC → 4 x Lmin
  • 55ºC → 8 x Lmin
  • 45ºC → 16 x Lmin
So, thermal design, including ample thermal conduction on the circuit board away from the LED and good airflow to remove heat from the vicinity all can have a significant effect on lifetime of an LED.
