Can you please help me with providing link for this particular resistor ? I’d like to purchase a few of them.
Thank you
Hey Rams,
The SMD resistor marking “56R0” indicates this is a 56ohm resistor. We have plenty of options to choose from HERE but to properly narrow down the list to the correct results we would need to know if there are any power and tolerance ratings that need to be met, as well as the physical dimensions of the resistor to get the correct package case. These parameters can be found at the top of the search page. There is a TechForum article HERE that talks about SMD part markings.
Thank you. I went ahead and measured the SMD resistor. It’s approx. 2.5mm length and 1.25mm wide with a height of .5mm
I don’t know how to figure out the power and tolerance required. My apologies. I’m just a DIY’er that enjoys soldering. I provided a couple diagrams (schematic) for that PCB. I used green arrows to point out the SMD resistor. If you can please help pick the right SMD.
I really appreciate it.
Thank you
Would you have dimensions for the resistor @Rams ?
Hi, Nathan
Yes, I do. . It’s approx. 2.5mm length and 1.25mm wide with a height of .5mm
Thank you
I found the 2019-RK73H2ATTD56R0FCT-ND
0.079" L x 0.049" W (2.00mm x 1.25mm)
Thank you.
Just placed an order.
