What is the wire gauge used for the above load cell part?
Thanks,
Chris
Hi Chris,
Welcome to the Digikey tech forum, I went through the documents for this part and wasn’t able to find the wire gauge size. I sent a request to our product manager and will post the information when I get it.
Thanks Steve!
Chris
Hi Chris,
The data sheet lists the wire with a diameter of 0.6mm but not knowing if that is the actual wire diameter or insulation diameter. We had the product measured and confirmed the data sheet lists the outside diameter of the insulation and not the wire , the diameter of the wire itself appears to be 30AWG for this sensor.
My thoughts exactly. Thanks for confirming the fine gauge of the wiring is indeed 30 ga!
Chris
