Hello everyone,
I’m new to linux.
At this section: Bootloader: imx_usb_loader
I received different behavior on my local ubuntu host and ubuntu on vm(windows host, virtual box V6.1.18). Anyone knows what’s wrong with my local ubuntu?
On my vm ubuntu, it ran successfully:
- terminal:
dylan@dylan-VirtualBox:~/u-boot$ sudo ~/imx_usb_loader/imx_usb SPL
config file </home/dylan/imx_usb_loader//imx_usb.conf>
vid=0x066f pid=0x3780 file_name=mx23_usb_work.conf
vid=0x15a2 pid=0x004f file_name=mx28_usb_work.conf
vid=0x15a2 pid=0x0052 file_name=mx50_usb_work.conf
vid=0x15a2 pid=0x0054 file_name=mx6_usb_work.conf
vid=0x15a2 pid=0x0061 file_name=mx6_usb_work.conf
vid=0x15a2 pid=0x0063 file_name=mx6_usb_work.conf
vid=0x15a2 pid=0x0071 file_name=mx6_usb_work.conf
vid=0x15a2 pid=0x007d file_name=mx6_usb_work.conf
vid=0x15a2 pid=0x0080 file_name=mx6ull_usb_work.conf
vid=0x1fc9 pid=0x0128 file_name=mx6_usb_work.conf
vid=0x15a2 pid=0x0076 file_name=mx7_usb_work.conf
vid=0x1fc9 pid=0x0126 file_name=mx7ulp_usb_work.conf
vid=0x15a2 pid=0x0041 file_name=mx51_usb_work.conf
vid=0x15a2 pid=0x004e file_name=mx53_usb_work.conf
vid=0x15a2 pid=0x006a file_name=vybrid_usb_work.conf
vid=0x066f pid=0x37ff file_name=linux_gadget.conf
vid=0x1b67 pid=0x4fff file_name=mx6_usb_sdp_spl.conf
vid=0x0525 pid=0xb4a4 file_name=mx6_usb_sdp_spl.conf
vid=0x1fc9 pid=0x012b file_name=mx8mq_usb_work.conf
vid=0x1fc9 pid=0x0134 file_name=mx8mm_usb_work.conf
vid=0x1fc9 pid=0x013e file_name=mx8mn_usb_work.conf
vid=0x3016 pid=0x1001 file_name=mx8m_usb_sdp_spl.conf
config file </home/dylan/imx_usb_loader//mx7_usb_work.conf>
parse /home/dylan/imx_usb_loader//mx7_usb_work.conf
Trying to open device vid=0x15a2 pid=0x0076
Interface 0 claimed
HAB security state: development mode (0x56787856)
== work item
filename SPL
load_size 0 bytes
load_addr 0x00000000
dcd 1
clear_dcd 0
plug 1
jump_mode 3
jump_addr 0x00000000
== end work item
No DCD table
loading binary file(SPL) to 00911400, skip=0, fsize=ac00 type=aa
<<<44032, 44032 bytes>>>
succeeded (security 0x56787856, status 0x88888888)
jumping to 0x00911400
dylan@dylan-VirtualBox:~/u-boot$ sudo ~/imx_usb_loader/imx_usb u-boot-dtb.img
config file </home/dylan/imx_usb_loader//mx6_usb_sdp_spl.conf>
parse /home/dylan/imx_usb_loader//mx6_usb_sdp_spl.conf
Trying to open device vid=0x0525 pid=0xb4a4
Interface 0 claimed
== work item
filename u-boot-dtb.img
load_size 0 bytes
dcd 1
clear_dcd 0
plug 1
jump_mode 3
== end work item
loading binary file(u-boot-dtb.img) to 877fffc0, skip=0, fsize=7a562 type=aa
<<<501090, 501090 bytes>>>
jumping to 0x877fffc0
- serial console:
U-Boot SPL 2021.01 (Feb 09 2021 - 14:45:16 +0800)
Trying to boot from USB SDP
SDP: initialize...
SDP: handle requests...
Downloading file of size 501090 to 0x877fffc0... done
Jumping to header at 0x877fffc0
Header Tag is not an IMX image
�ound header at 0x877fffc0
U-Boot 2021.01 (Feb 09 2021 - 14:45:16 +0800)
CPU: Freescale i.MX7D rev1.2 1000 MHz (running at 792 MHz)
CPU: Commercial temperature grade (0C to 95C) at 38C
Reset cause: POR
Model: TechNexion PICO-IMX7D Board and PI baseboard
Board: i.MX7D PICOSOM
I2C: ready
DRAM: 1 GiB
PMIC: PFUZE3000 DEV_ID=0x30 REV_ID=0x11
MMC: FSL_SDHC: 2, FSL_SDHC: 1, FSL_SDHC: 0
Loading Environment from MMC... OK
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@30be0000
Hit any key to stop autoboot: 0
=> env default -f -a
## Resetting to default environment
## Error: Can't force access to "bootcmd"
## Error: Can't force access to "bootdelay"
## Error: Can't force access to "baudrate"
## Error: Can't force access to "loadaddr"
## Error: Can't force access to "arch"
## Error: Can't force access to "cpu"
## Error: Can't force access to "board"
## Error: Can't force access to "board_name"
## Error: Can't force access to "vendor"
## Error: Can't force access to "soc"
## Error: Can't force access to "image"
## Error: Can't force access to "splashpos"
## Error: Can't force access to "splashimage"
## Error: Can't force access to "console"
## Error: Can't force access to "fdt_high"
## Error: Can't force access to "initrd_high"
## Error: Can't force access to "fdtfile"
## Error: Can't force access to "videomode"
## Error: Can't force access to "fdt_addr"
## Error: Can't force access to "fdt_addr_r"
## Error: Can't force access to "kernel_addr_r"
## Error: Can't force access to "pxefile_addr_r"
## Error: Can't force access to "ramdisk_addr_r"
## Error: Can't force access to "ramdiskaddr"
## Error: Can't force access to "scriptaddr"
## Error: Can't force access to "dfu_alt_info"
## Error: Can't force access to "findfdt"
## Error: Can't force access to "finduuid"
## Error: Can't force access to "partitions"
## Error: Can't force access to "fastboot_partition_alias_system"
## Error: Can't force access to "setup_emmc"
## Error: Can't force access to "bootmenu_0"
## Error: Can't force access to "bootmenu_1"
## Error: Can't force access to "bootmenu_2"
## Error: Can't force access to "bootmenu_3"
## Error: Can't force access to "mmc_boot"
## Error: Can't force access to "boot_net_usb_start"
## Error: Can't force access to "usb_boot"
## Error: Can't force access to "boot_efi_bootmgr"
## Error: Can't force access to "boot_efi_binary"
## Error: Can't force access to "load_efi_dtb"
## Error: Can't force access to "efi_dtb_prefixes"
## Error: Can't force access to "scan_dev_for_efi"
## Error: Can't force access to "boot_prefixes"
## Error: Can't force access to "boot_scripts"
## Error: Can't force access to "boot_script_dhcp"
## Error: Can't force access to "boot_targets"
## Error: Can't force access to "boot_syslinux_conf"
## Error: Can't force access to "boot_extlinux"
## Error: Can't force access to "scan_dev_for_extlinux"
## Error: Can't force access to "boot_a_script"
## Error: Can't force access to "scan_dev_for_scripts"
## Error: Can't force access to "scan_dev_for_boot"
## Error: Can't force access to "scan_dev_for_boot_part"
## Error: Can't force access to "bootcmd_mmc0"
## Error: Can't force access to "bootcmd_usb0"
## Error: Can't force access to "bootcmd_pxe"
## Error: Can't force access to "bootcmd_dhcp"
## Error: Can't force access to "distro_bootcmd"
=> setenv bootm_boot_mode nonsec
=> saveenv
Saving Environment to MMC... Writing to MMC(0)... OK
=> mmcpartconf 0 0 7 0
Unknown command 'mmcpartconf' - try 'help'
=> mmc partconf 0 0 7 0
=> dfu 0 mmc 0
#DOWNLOAD ... OK
Ctrl+C to exit ...
#DOWNLOAD ... OK
Ctrl+C to exit ...
On my local ubuntu, the serial console stuck after DRAM:
- terminal:
user@user-P453UJ:~/u-boot$ sudo ~/imx_usb_loader/imx_usb SPL
config file </home/user/imx_usb_loader//imx_usb.conf>
config file </home/user/imx_usb_loader//mx7_usb_work.conf>
parse /home/user/imx_usb_loader//mx7_usb_work.conf
Interface 0 claimed
== work item
filename SPL
load_size 0 bytes
dcd 1
clear_dcd 0
plug 1
jump_mode 3
== end work item
No DCD table
user@user-P453UJ:~/u-boot$ sudo ~/imx_usb_loader/imx_usb u-boot-dtb.img
config file </home/user/imx_usb_loader//mx6_usb_sdp_spl.conf>
parse /home/user/imx_usb_loader//mx6_usb_sdp_spl.conf
Interface 0 claimed
== work item
load_size 0 bytes
dcd 1
clear_dcd 0
plug 1
jump_mode 3
== end work item
- serial console:
U-Boot SPL 2021.01 (Feb 16 2021 - 16:15:36 +0800)
SDP: initialize...
U-Boot 2021.01 (Feb 16 2021 - 16:15:36 +0800)
CPU: Commercial temperature grade (0C to 95C) at 36C
Reset cause: POR
I2C: ready
DRAM: 1 GiB
