I am looking for a part that can covert my digital signal to an analog signal that has a range of -10 to 10 volts.
Greetings,
The DAC IC product family is here; use the parametric filters to reduce the number of options on the basis of your other preferences, such type of digital interface, resolution, etc. The “Voltage-Supply, Analog” attribute can be used as a proxy for output range; in order to provide a +/- 10V output, most devices will require and analog supply of at least +/- 10V.
