Looking for female connector for this power supply
------Question for ADT-150B12AA J-A Please Put your question below------
Welcome to the TechForum angarcia ! I assume you are talking about the output connector in this instance, which is a 5.1 by 7.4mm by 11mm barrel plug. How do you want to mount the mating connector? Do you want something that hangs off a cable, something that is board mounted, something that is mounted to a panel, or something else?
Surface mount will work
The only one I see for this is this part, 2223-PJ-096HCT-ND. 5.1 by 7.4 isn’t very common.
thanks I’ll give it a try
