Doing a new board design and looking for suggestions for a daughter board connection capability that will support high power connection. The boards will be parallel to each other
High power , at least 70 amps, 30V
Thru-hole
Space efficient. This is going inside a drone so space and weight are at a premium
Ideally the ability to have some choice of distance between the boards.
Hi Steve we will need at least two pins, one each for +/-. But for a connector with individual pins at lower amperage capability we would need multiple parallel pins.
A pair of connectors you can look at are 1195-15520122701000CT-ND for the male connector, and 1195-15620122701000CT-ND for the female connector. Each is 12 pins, and each contact can handle up to 19A @ 180V. Please check the datasheets for compatibility to your application.
Thinking a bit differently, one might also note that products such as the 7466004 are available which potentially could serve both a mechanical and electrical function. Similar products are available under the guise of board standoffs, though one would want to take careful note of any solderability issues due to plating/materials. Pin sockets might be another idea to contemplate.
