Looking for power supply by PowerBox OBR03046C
I am looking for the part PowerBox OBR03046C
I need either a part PowerBox OBR03046C power supply or an alertnate part, any help on this issue.
Hello dmoneo,
Welcome to the DigiKey TechForum! We do carry PowerBox as a manufacturer, however the OBR03 Series is not part of our catalog at this time. Using the datasheet for this part, I was able to find that the ‘C’ suffix stands for “enclosed” as well as see that this is a single output power supply as per the picture below:
Taking a look through our catalog, there are some similar Powerbox parts that are made for industrial use, but we do not carry any power supplies from Powerbox with enough output power that are also intended for medical use.
If you are interested in something from another manufacturer, I suggest taking a look at part 3989-TAAM700-14C-ND to see if that will work for you.
Regards,
Klint
Thanks Klint. I will look at these alternatives.
