Looks like a 26 pin if I counted correctly.
Unfortunately we do not carry a 26 pin cable like this one.
Looks like it’s 25 pin, we may have something like this.
What is the length and width measurements of the cable? Is it about an inch wide?
26 cm x 2,6 cm 25P double side contact
Thanks for the information. Take a look at one of these flat flex cables 2 are 25.4cm and the other two are 30.4cm. You will need to choose the length that works best for you.
thank you…i have made a mistake they are not Top on Both Sides, Backers on Both Sides, on one side and the same…
