Does anyone know where I can find one of these? Thank you!
Hello and welcome to the TechForum. That is going to be a very application specific part you would have to contact the original manufacturer for a replacement
It looks like we do not carry that exact part.
If you need a power supply to work this part 1470-2774-ND could be a option. This will have a barrel connector on it , but you could cut it off if you need just wire leads.
I have a plug that fits into this adaptor, but as you can see, it’s very unique, it powers the neon light inside a retro clock. I have two of the clocks but only one adaptor. Trying to complete the second set. Thanks for your help!
Thanks so much for the info! I really appreciate the suggestion. I’ll check out the 1470-2774-ND part—cutting off the barrel connector to get wire leads sounds like a workable solution. Thanks again for taking the time to help out!
