M2S010-MKR-KIT serial Flash
I am new SPI serial flash , AT25DF641 is serial Flash in M2S010-MKR-KIT so I need to write to all the locations and read all the locations, erase all, so could any one provide headers files of AT25DF641 and simple project for R/W of serial flash. I just follow the m2s_tu0548_liberov11p7_df tutorial but its not worked out.
And edit the at25df641drives files as per my AT25DF641 flash device & my main.c code is :slight_smile:
#include "drivers/mss_pdma/mss_pdma.h"
#include "drivers/mss_spi/mss_spi.h"
#include "drivers/at25df641/at25df641.h"
#include "drivers/mss_uart/mss_uart.h"
#include <string.h>
#include <stdio.h>
#define BUFFER_A_SIZE  10
/* Manufactuer and device IDs for Atmel AT25DF641 SPI Flash. */
#define FLASH_MANUFACTURER_ID   0x1F		//(uint8_t)0x1F
#define FLASH_DEVICE_ID         0x48		//(uint8_t)0x48
 * Static global variables
static uint8_t g_flash_wr_buf[BUFFER_A_SIZE];
static uint8_t g_flash_rd_buf[BUFFER_A_SIZE];
  Messages displayed over the UART.
const uint8_t g_greeting_msg[] =
"\r\n\r\n\
**********************************************************************\r\n\
***************** SmartFusion2 MSS SPI Flash example *****************\r\n\
This example project demonstrates the use of the SmartFusion2 MSS SPI\r\n\
block.It reads and writes the content of an AT25SF161SPI flash device\r\n\
---------------------------------------------------------------------\r\n";
 * main function.
int main()
    volatile uint32_t errors = 0;
    uint32_t address = 0;
    uint16_t loop_count;
    uint8_t i;
    uint8_t manufacturer_id = 0;
    uint8_t device_id = 0;
    /* Disable Watchdog */
    SYSREG->WDOG_CR = 0x00000000;
    MSS_UART_init(&g_mss_uart1,
                       MSS_UART_115200_BAUD,
                       MSS_UART_DATA_8_BITS | MSS_UART_NO_PARITY | MSS_UART_ONE_STOP_BIT);
    MSS_UART_polled_tx_string(&g_mss_uart1, g_greeting_msg);
     * Initialize the write and read Buffers
    for(loop_count = 0; loop_count <(BUFFER_A_SIZE); loop_count++)
        g_flash_wr_buf[loop_count] = loop_count;
        g_flash_rd_buf[loop_count] = 0x00;
     * Flash Driver Initialization
    FLASH_init();
    FLASH_global_unprotect();
    FLASH_erase_4k_block(0);
     * Check SPI Flash part manufacturer and device ID.
  /*  FLASH_read_device_id(&manufacturer_id, &device_id);
    if ((manufacturer_id != FLASH_MANUFACTURER_ID) || (device_id != FLASH_DEVICE_ID))
       ++errors;
     * Write Data to Flash.
    address = 100;
    printf("\n\r Writing data 0 - 9 to Flash\n\r");
    FLASH_program(address, g_flash_wr_buf, sizeof(g_flash_wr_buf));
     * Read Data From Flash.
    address = 100;
    printf( " \n\r Read Data From Flash \n\r ");
    FLASH_read(address, g_flash_rd_buf, sizeof(g_flash_wr_buf));
    for(i=0;i<(BUFFER_A_SIZE);i++)
    	printf("\n\r %d",g_flash_rd_buf[i]);
    printf( " \n\r\n\r External Flash write and read operations are successful \n\r ");
   while(1)
    return 0;
and my UART screen is shown below after I type 10 values but nothing happening here, so where did I do mistakes or is there any mistakes in header files ?, please guide me to solve R/W of Flash.
Best regards,
varsh
So based on your UART output, your code isn’t reaching the “write data to flash” section?
I don’t see anything wrong with the code itself, but you can assume something happened between the initialization of your buffers and the flash initialization.
I’d recommend stepping through your code with the debugger in SoftConsole and try to find the point where the program is getting stuck. Or try to read the device IDs and see if the SPI is actually working.
Thank you for reply,
My quetions is “is there any problem with header files ?” and how to check the SPI is working or not ?
I am unable to send Zip files of header files so I am attaching here only.
#include "at25df641.h"
#include "../mss_spi/mss_spi.h"
#include "../mss_pdma/mss_pdma.h"
 * Local Defines
 * Macro To Enable SPI-FLASH with PDMA
#define SPI_FLASH_WITH_PDMA
#define READ_ARRAY_OPCODE   0x0B		//0x1B
#define DEVICE_ID_READ      0x9F
#define WRITE_ENABLE_CMD    0x06
#define WRITE_DISABLE_CMD   0x04
#define PROGRAM_PAGE_CMD    0x02
#define WRITE_STATUS1_OPCODE    0x01
#define CHIP_ERASE_OPCODE   0x60
#define ERASE_4K_BLOCK_OPCODE   0x20
#define ERASE_32K_BLOCK_OPCODE  0x52
#define ERASE_64K_BLOCK_OPCODE  0xD8
#define READ_STATUS         0x05
#define DMA_TRANSFER_SIZE    32u
#define READY_BIT_MASK      0x01
#define UNPROTECT_SECTOR_OPCODE     0x39
#define DONT_CARE       0
#define NB_BYTES_PER_PAGE   256
 * Local functions
static void wait_ready(void);
static void program_flash(uint32_t, uint8_t *, size_t);
 * See st25df641.h for description of this function.
void FLASH_init(void)
#ifdef SPI_FLASH_WITH_PDMA
     * Configure DMA channel used as part of this SPI Flash driver.
    PDMA_init();
     * Configure PDMA channel 0 to perform a memory to MMUART0 byte transfer
     * incrementing source address after each transfer and no increment for
     * destination address.
    PDMA_configure(PDMA_CHANNEL_0,
                   PDMA_TO_SPI_0,
                   PDMA_BYTE_TRANSFER | PDMA_LOW_PRIORITY | PDMA_INC_SRC_ONE_BYTE | PDMA_NO_INC,
                   PDMA_DEFAULT_WRITE_ADJ);
     * Configure PDMA channel 1 to perform a MMUART0 to memory byte transfer
     * incrementing the destination address after each transfer
     * and No increment of source address.
    PDMA_configure(PDMA_CHANNEL_1,
                   PDMA_FROM_SPI_0,
                   PDMA_BYTE_TRANSFER | PDMA_LOW_PRIORITY | PDMA_NO_INC | PDMA_INC_DEST_ONE_BYTE,
#endif
     * Configure SPI.
    MSS_SPI_init(&g_mss_spi0);
    MSS_SPI_configure_master_mode(&g_mss_spi0,
                                   MSS_SPI_SLAVE_0,
                                   MSS_SPI_MODE3,
                                   256u,
                                   MSS_SPI_BLOCK_TRANSFER_FRAME_SIZE);
void FLASH_read_device_id
    uint8_t * manufacturer_id,
    uint8_t * device_id
    uint8_t read_buffer[3];
    uint8_t dummy[3];
    dummy[0] = DEVICE_ID_READ;
    MSS_SPI_set_slave_select(&g_mss_spi0, MSS_SPI_SLAVE_0);
    MSS_SPI_disable(&g_mss_spi0);
    MSS_SPI_set_transfer_byte_count(&g_mss_spi0, 3);
    PDMA_start(PDMA_CHANNEL_0,
               (uint32_t)dummy,
               PDMA_SPI0_TX_REGISTER,
               sizeof(read_buffer));
    PDMA_start(PDMA_CHANNEL_1,
               PDMA_SPI0_RX_REGISTER,
               (uint32_t)read_buffer,
    MSS_SPI_enable(&g_mss_spi0);
    while (!MSS_SPI_tx_done(&g_mss_spi0))
    MSS_SPI_clear_slave_select(&g_mss_spi0, MSS_SPI_SLAVE_0);
    *manufacturer_id = read_buffer[1];
    *device_id = read_buffer[2];
#else
    MSS_SPI_transfer_block(&g_mss_spi0, dummy, 1, read_buffer, 2);
    *manufacturer_id = read_buffer[0];
    *device_id = read_buffer[1];
#endif
void FLASH_read
    uint32_t address,
    uint8_t * rx_buffer,
    size_t size_in_bytes
    uint8_t cmd_buffer[6];
    uint32_t transfer_size;
    uint32_t count;
    uint8_t *ptr;
    uint8_t *dst_ptr;
    cmd_buffer[0] = READ_ARRAY_OPCODE;
    cmd_buffer[1] = (uint8_t)((address >> 16) & 0xFF);
    cmd_buffer[2] = (uint8_t)((address >> 8) & 0xFF);;
    cmd_buffer[3] = (uint8_t)(address & 0xFF);
    cmd_buffer[4] = DONT_CARE;
    cmd_buffer[5] = DONT_CARE;
    ptr = &cmd_buffer[0];
    * To Allocate buffer dynamically to store the read the data from flash.
    dst_ptr = (uint8_t *) malloc((size_in_bytes*sizeof(uint8_t))+ sizeof(cmd_buffer));
    if(dst_ptr != NULL)
        transfer_size = (size_in_bytes + sizeof(cmd_buffer));
        wait_ready();
        MSS_SPI_set_transfer_byte_count(&g_mss_spi0, transfer_size);
        PDMA_start(PDMA_CHANNEL_0,          /* channel_id */
                   (uint32_t)ptr,           /* src_addr */
                   PDMA_SPI0_TX_REGISTER,   /* dest_addr */
                   transfer_size);
        PDMA_start(PDMA_CHANNEL_1,          /* channel_id */
                   PDMA_SPI0_RX_REGISTER,   /* src_addr */
                   (uint32_t)dst_ptr,       /* dest_addr */
                   transfer_size);
        while(!MSS_SPI_tx_done(&g_mss_spi0))
        for(count = 0; count < size_in_bytes; count++)
            rx_buffer[count] = dst_ptr[6+count];
        free(dst_ptr);
    else
#else
    wait_ready();
    MSS_SPI_transfer_block(&g_mss_spi0, cmd_buffer, sizeof(cmd_buffer), rx_buffer, size_in_bytes);
    wait_ready();
#endif
void FLASH_global_unprotect(void)
    uint8_t cmd_buffer[2];
    /* Send Write Enable command */
    cmd_buffer[0] = WRITE_ENABLE_CMD;
    wait_ready();
    MSS_SPI_transfer_block(&g_mss_spi0, cmd_buffer, 1, 0, 0);
    /* Send Chip Erase command */
    cmd_buffer[0] = WRITE_STATUS1_OPCODE;
    cmd_buffer[1] = 0;
    wait_ready();
    MSS_SPI_transfer_block(&g_mss_spi0, cmd_buffer, 2, 0, 0);
    wait_ready();
void FLASH_chip_erase(void)
    uint8_t cmd_buffer;
    cmd_buffer = WRITE_ENABLE_CMD;
    wait_ready();
    MSS_SPI_transfer_block(&g_mss_spi0, &cmd_buffer, 1, 0, 0);
    cmd_buffer = CHIP_ERASE_OPCODE;
    wait_ready();
    wait_ready();
void FLASH_erase_4k_block
    uint32_t address
    uint8_t cmd_buffer[4];
    wait_ready();
    cmd_buffer[0] = ERASE_4K_BLOCK_OPCODE;
    cmd_buffer[1] = (address >> 16) & 0xFF;
    cmd_buffer[2] = (address >> 8) & 0xFF;
    cmd_buffer[3] = address & 0xFF;
    wait_ready();
    MSS_SPI_transfer_block(&g_mss_spi0, cmd_buffer, sizeof(cmd_buffer), 0, 0);
    wait_ready();
void write_cmd_data
    mss_spi_instance_t * this_spi,
    const uint8_t * cmd_buffer,
    uint16_t cmd_byte_size,
    uint8_t * data_buffer,
    uint16_t data_byte_size
    transfer_size = cmd_byte_size + data_byte_size;
     * Register the PDMA handler that will feed the PDMA channel.
    MSS_SPI_disable(this_spi);
    MSS_SPI_set_transfer_byte_count(this_spi, transfer_size);
               (uint32_t)cmd_buffer,   /* src_addr */
               cmd_byte_size);
    PDMA_load_next_buffer(PDMA_CHANNEL_0,         /* channel_id */
                          (uint32_t)data_buffer,  /* src_addr */
                          data_byte_size);
    MSS_SPI_enable(this_spi);
    while (!MSS_SPI_tx_done(this_spi))
#else
    uint8_t tx_buffer[516];
    uint16_t transfer_size;
    uint16_t idx = 0;
    for(idx = 0; idx < cmd_byte_size; ++idx)
        tx_buffer[idx] = cmd_buffer[idx];
    for(idx = 0; idx < data_byte_size; ++idx)
        tx_buffer[cmd_byte_size + idx] = data_buffer[idx];
    MSS_SPI_transfer_block(&g_mss_spi0, tx_buffer, transfer_size, 0, 0);
#endif
    uint32_t address,
    uint8_t * write_buffer,
    wait_ready();
    /* Unprotect sector */
    cmd_buffer[0] = UNPROTECT_SECTOR_OPCODE;
    wait_ready();
    wait_ready();
    wait_ready();
    /* Program page */
    wait_ready();
    cmd_buffer[0] = PROGRAM_PAGE_CMD;
    write_cmd_data(&g_mss_spi0,
                   cmd_buffer,
                   sizeof(cmd_buffer),
                   write_buffer,
                   size_in_bytes);
    /* Send Write Disable command. */
    cmd_buffer[0] = WRITE_DISABLE_CMD;
    wait_ready();
uint8_t FLASH_get_status(void)
    uint8_t status;
    uint8_t command = READ_STATUS;
                           &command,
                           sizeof(uint8_t),
                           &status,
                           sizeof(status));
    return status;
    uint8_t ready_bit;
    do {
        MSS_SPI_transfer_block(&g_mss_spi0, &command, sizeof(command), &ready_bit, sizeof(ready_bit));
        ready_bit = ready_bit & READY_BIT_MASK;
    } while(ready_bit == 1);
void FLASH_program
    uint32_t address,
    uint32_t in_buffer_idx;
    uint32_t nb_bytes_to_write;
    uint32_t target_addr;
    in_buffer_idx = 0;
    nb_bytes_to_write = size_in_bytes;
    target_addr = address;
    while (in_buffer_idx < size_in_bytes)
        uint32_t size_left;
        nb_bytes_to_write = 0x100 - (target_addr & 0xFF);   /* adjust max possible size to page boundary. */
        size_left = size_in_bytes - in_buffer_idx;
        if (size_left < nb_bytes_to_write)
            nb_bytes_to_write = size_left;
        program_flash(target_addr, &write_buffer[in_buffer_idx], nb_bytes_to_write);
        target_addr += nb_bytes_to_write;
        in_buffer_idx += nb_bytes_to_write;
Is there any mistakes ?
Thank you.
This looks just like the Microchip example drivers. Is that file taken from a specific example or have you modified it? It’s not from the TU0548 you originally mentioned. The winbond.c and .h files from that project should be a good starting point.
Also are you intending to use the DMA for transactions? Did you enable it in Libero?
To check if SPI is working correctly, try to read the device IDs and print them to the UART or however you want to display them.
uint8_t manufacturer_id;
uint8_t device_id;
uint8_t read_buffer[2];
MSS_SPI_init( &g_mss_spi0 );
        &g_mss_spi0,
        MSS_SPI_SLAVE_0,
        MSS_SPI_MODE3,
        8,
// This is the same as the FLASH_read_device_id function
cmd_buffer[0] = 0x9F;
cmd_buffer[1] = 0x0;
cmd_buffer[2] = 0x0;
cmd_buffer[3] = 0x0;
MSS_SPI_set_slave_select( &g_mss_spi0, MSS_SPI_SLAVE_0 );
MSS_SPI_transfer_block( &g_mss_spi0, cmd_buffer, 4, read_buffer, sizeof(read_buffer) );
MSS_SPI_clear_slave_select( &g_mss_spi0, MSS_SPI_SLAVE_0 );
printf("Manufacturer id is %x\n\r", manufacturer_id);
printf("Device id is %x\n\r", device_id);
From the SPI flash datasheet you know the result should be the values shown below:
The SPI is working correctly, because I got Manufacturer Id is (0x1F) , Device Id (0x86) perfectly.
example code for writing and reading of the serial flash.
#define BUFFER_A_SIZE 5
void main(){
uint8_t i;
FLASH_init();
address = 200;
MSS_UART_polled_tx_string(&g_mss_uart1, g_flash_wr_buf);
address = 200;
MSS_UART_polled_tx_string( &g_mss_uart1,(const uint8_t*)"\n\r the read values are: \n\r " );
MSS_UART_polled_tx_string(&g_mss_uart1, g_flash_rd_buf);
   while(1)
return 0;
when I debug it perfectly showing the values as shown in the below screenshot but I didnt get any output on putty so where may be the the mistakes in my code ? so please give me the right solution.
Thanks in advance.
I suspect the problem is how you’re printing the data. If SPI is working and you successfully read back the data into your read buffer (you can double check this in the debugger), it would have the values 0 through 4. Then you’re sending those directly to the UART without converting them to ASCII which would cause them not to display correctly. printf("%d") would handle that for you, but that doesn’t appear to be working. Try adding an offset of 48 to each value to see if the digits are properly displayed on the terminal using the MSS_UART_polled_tx_string function.
uint8_t ascii_buf[BUFFER_A_SIZE];
for(i = 0; i< BUFFER_A_SIZE; i++) {
    ascii_buf[i] = g_flash_rd_buf[i] + 48;
MSS_UART_polled_tx_string(&g_mss_uart1, ascii_buf);
Be careful about using printf. It requires special setup to work properly. It doesn’t automatically know which UART is connected to your terminal which I’m assuming is why none of the printf statements appear in your screenshots. The original tutorial had an example of how to configure this, if needed.
Still I am unable to communicate with the serial flash and the CS pin is always high please guide me from the scatch to communicate with Flash device.
Best regards
I’m not completely clear on your current status. Please clarify the points below:
  • You are not communicating with the flash but you are able to read the device IDs, correct? This implies SPI is working to at least some degree.
  • Are you trying to use the PDMA for transfers? The original tutorial you referenced does not use or enable the PDMA, but the code you posted above is expecting to use it.
  • Have you verified the contents of the receive buffer after FLASH_read() with the debugger? Do you know for sure that it did not receive the data and that the issue isn’t a matter of it not displaying on the terminal?
