The list of port names and corresponding pin numbers for M2S010-MKR-KIT to use in libero
To use in libero I need information regarding the device M2S010-MKR-KIT, especially the list of port names and corresponding pin numbers . The quick start guide provided with this device does not have required information.
Also the pdf I have checked only have pin numbers.Can you help me with this?
HI @shef , welcome ot the forum!
I’ve updated and fixed an old article on doing this here: For some reason, all the photos didn’t make the eewiki → forum transition, so they are fixed now:
https://forum.digikey.com/t/getting-started-with-the-microsemi-smartfusion-2-maker-board/11165
There is also this documentation:
Regards,
But sir what I need is the pin number corresponding to the Port name as shown in figure.
I also got links regarding the pin numbers but to do libero I need Pin numbers corresponding to Port name
Can you please help me with this?
There is a schematic here:
https://forum.digikey.com/uploads/short-url/2WxYDppsgH5ljsnoeX1fSsJl8gZ.pdf
Import this Example project to see if they have the pin numbers setup:
Regards,
Sir, that has the port names and corresponding pin numbers for led alone. But I need the pin numbers for the port names that I have shown in the images.
For example what is the pin number corresponding to FAB_CCC_GL0, FAB_CCC_LOCK, I2C_0_SCL_F2M etc
Kindly help me with this
