MacBook Pro (A2991) FPC Battery Connector
I damaged my computer while taking it apart to clean it. It’s a 2023 MacBook Pro (A2991). I am looking for the FPC Battery connector that’s soldered onto the motherboard. Any help finding one would be greatly appreciate. It’s 8 pins.
@Kristof_2649 any ideas on this? TIA
I believe I found the correct part. Just looking for confirmation FH34SRJ-8S-0.5SH(50) Hirose Electric Co Ltd | Connectors, Interconnects | DigiKey…_gsMQ…&gclid=CjwKCAiApsm7BhBZEiwAvIu2X3fcOq_ka1LpqvsBHeRGR-jaUdW-FVVnwAhWed9F9SvLsfv5XzDe_xoCxzIQAvD_BwE&gclsrc=aw.dss
The part you are looking at you would want to check the following dimensions with a calipers to verify:
My 2019 15" A1990 motherboard 6 pin battery connector locking lever/clip/latch has “DDK” printed on it with the number 6. I believe, but am not sure, that it’s from the manufacturer DDK. https://www.ddknet.co.jp/English/products/fpc-connectors.html The FF14A series seems correct. I had a look at the STEP file in Freecad and it looks right.
These guys sell the 6 pin version, I didn’t see the 8 pin version. https://www.mobilesentrix.ca/battery-fpc-connector-for-macbook-pro-13-15-16-a1706-a1990-a1707-a2141-6-pin
Hello! I have the same problem with my MacBook A2991 - the connector is torn off the motherboard and the connector contacts are broken. I want to know how your problem was solved?
