Male and corresponding male and female Mini-Molex Med-Associates connectors assembly part numbe
Male and corresponding male and female Mini-Molex Med-Associates connectors assembly part number?
Do anyone knows what the number parts are to replace the mini-Molex connectors
Thank you all in advance
Possibly 0003062032 Molex | Connectors, Interconnects | DigiKey
0003061032 Molex | Connectors, Interconnects | DigiKey
Click here for contacts
I really appreciate the info, do you know what pins would be the ones to choose that are compatible with Med-Associates cables as well by any chance?
All of the pins in the above link would work with these connectors, you just want to match the wire gauge (AWG) size to your cable. The options are 18-24AWG wire size or 24-30AWG.
The other choice to make is if you want Gold or Tin Plated, normally you stick to the plating type on the existing connectors, I’m guessing Tin in this case.
I really appreciate you sharing this information!
