Material Identification: SBR12U45LH1-13
I am trying to track down the material composition of the leads on the SBR12U45LH1-13 device. Spec sheet doesn’t explicitly say, just hints at tin coatings. I suspect it is copper lead with SnAg, SnCu, and SnAgCu coating, but unsure. (Likely SnCu from XRF readings). Any insight?
Welcome to the DigiKey TechForum. In this case you will want to ask for a material declaration for the part through this document request link.
