When working with Silicon Labs’ EFR32xG22E wireless device, accurate power measurement and profiling are important to ensure your system operates reliably within the limits of harvested energy.
To design an efficient energy harvesting application, you need clear insights into:
- How much energy is needed per task
- Which operations consume the most power
- When and how energy is being consumed
- How often the device wakes up
Tools & Techniques for Power Measurement
Voltage Monitoring (V_MCU)
Monitoring shows how much voltage is available at the supply input and helps to verify if the PMIC and energy storage device (e.g., supercapacitor) are supplying sufficient energy for reliable operation.
Tools to use:- Digital Multimeter (DMM): For static checks
- IADC on EFR32xG22E: Use internal ADC to measure voltages like AVDD, IOVDD, or external analog inputs
- Oscilloscope: For viewing real-time voltage variations
Current Profiling (I_MCU)
Current profiling shows how much current the MCU draws over time, helping you pinpoint exactly when the device uses energy, such as during: RAM retention, flash erases/write and data processing, etc.
Key measurement techniques:- Shunt Resistor + Oscilloscope:
Insert a 10 Ω resistor in series with the supply path. Measure the voltage drop across it (Ohm’s law: V = IR). - DC Power Analyzer (e.g., Agilent/Keysight N6705B):
Set up as an ammeter in series with the supply. This tool provides high-resolution current traces, helping you monitor entire operation cycles—harvest, store, transmit, and sleep.
Applicable Part Numbers
DigiKey Part Number | Manufacturer Part Number |
336-EFR32MG22E224F512IM32-C-ND | EFR32MG22E224F512IM32-C |
336-EFR32MG22E224F512IM40-C-ND | EFR32MG22E224F512IM40-C |
336-EFR32MG22E224F512IM32-CRTR-ND | EFR32MG22E224F512IM32-CR |
336-EFR32MG22E224F512IM40-CRTR-ND | EFR32MG22E224F512IM40-CR |
336-XG22-EK2710A-ND | XG22-EK2710A |
336-SLWSTK6104A-ND | SLWSTK6104A |
336-SLWRB4311B-ND | SLWRB4311B |
336-XG22-RB4415A-ND | XG22-RB4415A |
336-XG22-EK8200A-ND | XG22-EK8200A |
336-MGM220PC22HNA2-ND | MGM220PC22HNA2 |
336-SLTB010A-ND | SLTB010A |
336-FG25-RB4270B-ND | FG25-RB4270B |
336-XG24-PK6010A-ND | XG24-PK6010A |
336-SLWSTK6021A-ND | SLWSTK6021A |
336-SLWRB4183A-ND | SLWRB4183A |
336-3934-ND | SLWRB4164A |
336-XG27-DK2602A-ND | XG27-DK2602A |
336-XG21-PK6026A-ND | XG21-PK6026A |
336-XG28-PK6024A-ND | XG28-PK6024A |
336-XG27-PK6017A-ND | XG27-PK6017A |
336-3972-ND | SLWSTK6020B |
336-SLWRB4182A-ND | SLWRB4182A |
336-5468-ND | SLWRB4306B |
336-SLWRB4181C-ND | SLWRB4181C |
336-4188-ND | SLWRB4257A |
336-SLWRB4181B-ND | SLWRB4181B |
336-4430-ND | SLWRB4170A |
336-FG25-RB4271A-ND | FG25-RB4271A |
336-FG25-RB4272A-ND | FG25-RB4272A |
336-FG25-PK6011A-ND | FG25-PK6011A |
336-FG25-PK6012A-ND | FG25-PK6012A |
336-WI-SUN-PK6015A-ND | WI-SUN-PK6015A |
336-XG28-RB4400C-ND | XG28-RB4400C |
336-XG26-DK2608A-ND | XG26-DK2608A |
336-XG26-PK6028A-ND | XG26-PK6028A |
336-XG24-DK2601B-ND | XG24-DK2601B |
336-BG22-RB4191A-ND | BG22-RB4191A |
336-SLWSTK6023A-ND | SLWSTK6023A |
336-XG24-PK6009A-ND | XG24-PK6009A |
336-5871-ND | SLWSTK6006A |
336-SLWSTK6007A-ND | SLWSTK6007A |
336-WI-SUN-PK6016A-ND | WI-SUN-PK6016A |
336-BGM220-EK4314A-ND | BGM220-EK4314A |
1568-20270-ND | 20270 |
776-453-00090-K1-ND | 453-00090-K1 |
336-XG27-RB4194A-ND | XG27-RB4194A |
336-SLWRB4312A-ND | SLWRB4312A |
336-XG28-EK2705A-ND | XG28-EK2705A |
336-XG24-RB4187C-ND | XG24-RB4187C |
336-XG24-RB4186C-ND | XG24-RB4186C |
336-XG28-RB4401C-ND | XG28-RB4401C |
336-XG24-RB4198A-ND | XG24-RB4198A |
336-3932-ND | SLWRB4162A |
336-FG23-RB4265B-ND | FG23-RB4265B |
336-FG23-DK2600A-ND | FG23-DK2600A |
336-XG21-PK6027A-ND | XG21-PK6027A |
336-XG28-PK6025A-ND | XG28-PK6025A |
336-XG24-PK6036A-ND | XG24-PK6036A |
336-4180-ND | SLWSTK6060B |
SLWRB4100A-ND | SLWRB4100A |
776-453-00091-K1-ND | 453-00091-K1 |
336-SLWRB4179B-ND | SLWRB4179B |
336-SLWRB4206A-ND | SLWRB4206A |
336-3965-ND | SLWRB4104A |
336-3930-ND | SLWRB4103A |
336-3968-ND | SLWRB4168A |
336-3931-ND | SLWRB4161A |
336-3935-ND | SLWRB4253A |
336-XG24-RB4188A-ND | XG24-RB4188A |
336-4192-ND | SLWRB4259A |
336-5473-ND | SLWRB4172B |
336-3971-ND | SLWRB4256A |
336-4189-ND | SLWRB4257B |
336-3966-ND | SLWRB4158A |
336-3936-ND | SLWRB4254A |
336-4181-ND | SLWSTK6061B |
336-4183-ND | SLWSTK6063B |
336-3967-ND | SLWRB4167A |
336-4190-ND | SLWRB4258A |
336-SLWRB4262A-ND | SLWRB4262A |
336-XG21-RB4196B-ND | XG21-RB4196B |
336-XG21-RB4195B-ND | XG21-RB4195B |
336-XG26-RB4118A-ND | XG26-RB4118A |
336-BG27-RB4110B-ND | BG27-RB4110B |
336-BG27-RB4111B-ND | BG27-RB4111B |
336-XG24-RB4115B-ND | XG24-RB4115B |
336-XG27-PK6018A-ND | XG27-PK6018A |
336-XG27-PK6019A-ND | XG27-PK6019A |
602-XK-9XR-DMM-5-ND | XK-9XR-DMM-5 |
336-3728-ND | SLWRB4150B |
336-4185-ND | SLWRB4105A |
336-4186-ND | SLWRB4169A |
336-4187-ND | SLWRB4169B |
336-3691-ND | SLWRB4154A |
336-5474-ND | SLWRB4174A |
336-4193-ND | RD-0098-0401 |
336-XG24-EK2703A-ND | XG24-EK2703A |
336-XG24-DK2606A-ND | XG24-DK2606A |
336-BG22-PK6022A-ND | BG22-PK6022A |
1597-102010590-ND | 102010590 |
1597-102010610-ND | 102010610 |
336-BG22-EK4108A-ND | BG22-EK4108A |
336-3970-ND | SLWRB4255A |
336-3969-ND | SLWRB4159A |
336-3933-ND | SLWRB4163A |
336-SLWRB4180B-ND | SLWRB4180B |
336-3723-ND | SLWRB4251A |
336-3724-ND | SLWRB4251B |
336-5472-ND | SLWRB4173A |
336-4191-ND | SLWRB4258B |
336-5475-ND | SLWRB4175A |
336-4182-ND | SLWSTK6062B |
336-3937-ND | SLWSTK6000B |
336-4285-ND | SLWRB4306C |
336-4286-ND | SLWRB4306D |
336-3722-ND | SLWRB4250B |
336-3721-ND | SLWRB4250A |
336-SLWRB4261A-ND | SLWRB4261A |
336-SLWRB4262B-ND | SLWRB4262B |
1597-102010690-ND | 102010690 |
1597-102010691-ND | 102010691 |
1597-102010692-ND | 102010692 |
1597-102010693-ND | 102010693 |
336-XG28S-EK2705A-ND | XG28S-EK2705A |
336-5471-ND | SLWRB4172A |
336-4184-ND | SLWSTK6065B |
SLWRB4101B-ND | SLWRB4101B |
336-3729-ND | SLWRB4150A |
336-XG23-RB4204D-ND | XG23-RB4204D |
336-5476-ND | SLWRB4174B |
336-XG23-RB4210A-ND | XG23-RB4210A |
336-4194-ND | RD-0100-0201 |
336-XG23-PK6067A-ND | XG23-PK6067A |
336-XG23-PK6068A-ND | XG23-PK6068A |
336-3720-ND | SLWSTK6065A |
SLWRB4151A-ND | SLWRB4151A |
336-3449-ND | SLWSTK6020A |
336-3466-ND | SLWSTK6000A |
336-3496-ND | SLWSTK6066A |
336-3738-ND | SLTB001A |
336-3716-ND | SLWSTK6060A |
336-3717-ND | SLWSTK6061A |
336-3718-ND | SLWSTK6062A |
336-3719-ND | SLWSTK6063A |
336-3725-ND | SLWRB4251D |
SLWSTK6001A-ND | SLWSTK6001A |
SLWSTK6002A-ND | SLWSTK6002A |
SLWRB4101A-ND | SLWRB4101A |
SLWRB4153A-ND | SLWRB4153A |
SLWSTK6003A-ND | SLWSTK6003A |
336-3802-ND | RD-0085-0401 |
336-4166-ND | SLTB004A |
336-4306-ND | RD-0099-0201 |
336-5872-ND | SLWRB4180A |
336-5873-ND | SLWRB4181A |
336-5897-ND | SLWRB4201A |
SLWRB4150C-ND | SLWRB4150C |
SLWRB4155A-ND | SLWRB4155A |
SLWRB4165B-ND | SLWRB4165B |
SLWSTK6040A-ND | SLWSTK6040A |
336-BRD4160A-ND | BRD4160A |
336-BRD4105A-ND | BRD4105A |
336-EFR32BG22C222F352GM32-C-ND | EFR32BG22C222F352GM32-C |
336-EFR32BG22C224F512GM40-C-ND | EFR32BG22C224F512GM40-C |
336-EFR32BG27C140F768IM40-B-ND | EFR32BG27C140F768IM40-B |
336-EFR32BG27C140F768IM32-B-ND | EFR32BG27C140F768IM32-B |
336-EFR32BG24A010F1024IM40-B-ND | EFR32BG24A010F1024IM40-B |
336-EFR32BG24A020F1024IM40-B-ND | EFR32BG24A020F1024IM40-B |
336-EFR32BG24B210F1024IM48-B-ND | EFR32BG24B210F1024IM48-B |
336-EFR32BG24B220F1024IM48-B-ND | EFR32BG24B220F1024IM48-B |
336-EFR32BG24A020F1024IM48-B-ND | EFR32BG24A020F1024IM48-B |
336-EFR32FG28A110F1024GM48-A-ND | EFR32FG28A110F1024GM48-A |
EFR32BG13P733F512GM48-D-ND | EFR32BG13P733F512GM48-D |
336-EFR32MG24B220F1536IM48-B-ND | EFR32MG24B220F1536IM48-B |
336-EFR32MG24A410F1536IM40-B-ND | EFR32MG24A410F1536IM40-B |
336-EFR32MG24B020F1536IM48-B-ND | EFR32MG24B020F1536IM48-B |
336-4219-ND | EFR32MG12P433F1024GM48-C |
336-EFR32BG22C112F352GM32-C-ND | EFR32BG22C112F352GM32-C |
336-EFR32BG22C224F512IM40-C-ND | EFR32BG22C224F512IM40-C |
336-EFR32BG22C224F512IM32-C-ND | EFR32BG22C224F512IM32-C |
336-EFR32BG22C224F512GN32-C-ND | EFR32BG22C224F512GN32-C |
336-EFR32MG22C224F512IM32-C-ND | EFR32MG22C224F512IM32-C |
336-EFR32MG27C140F768IM40-B-ND | EFR32MG27C140F768IM40-B |
336-EFR32FG23A010F256GM40-C-ND | EFR32FG23A010F256GM40-C |
336-EFR32BG24B110F1536IM48-B-ND | EFR32BG24B110F1536IM48-B |
336-5869-2-ND,336-5869-1-ND,336-5869-6-ND | EFR32BG21A010F1024IM32-BR |
336-5870-2-ND,336-5870-1-ND,336-5870-6-ND | EFR32BG21A020F1024IM32-BR |
336-EFR32MG24B010F1536IM40-B-ND | EFR32MG24B010F1536IM40-B |
336-EFR32MG24A010F1536IM40-B-ND | EFR32MG24A010F1536IM40-B |
336-5868-2-ND,336-5868-1-ND,336-5868-6-ND | EFR32MG21A020F1024IM32-BR |
336-EFR32MG13P632F512GM48-DRTR-ND,336-EFR32MG13P632F512GM48-DRCT-ND,336-EFR32MG13P632F512GM48-DRDKR-ND | EFR32MG13P632F512GM48-DR |
336-EFR32FG28B320F1024IM48-A-ND | EFR32FG28B320F1024IM48-A |
336-EFR32MG24B210F1536IM48-B-ND | EFR32MG24B210F1536IM48-B |
336-5793-ND | EFR32MG12P332F1024GM48-C |
336-EFR32FG28B322F1024IM48-A-ND | EFR32FG28B322F1024IM48-A |
336-EFR32FG28B322F1024IM68-A-ND | EFR32FG28B322F1024IM68-A |
336-EFR32MG12P232F1024GM48-CRTR-ND,336-EFR32MG12P232F1024GM48-CRCT-ND,336-EFR32MG12P232F1024GM48-CRDKR-ND | EFR32MG12P232F1024GM48-CR |
336-EFR32BG22C222F352GM40-C-ND | EFR32BG22C222F352GM40-C |
336-EFR32FG22C121F512GM40-C-ND | EFR32FG22C121F512GM40-C |
336-EFR32MG22C224F512IM40-C-ND | EFR32MG22C224F512IM40-C |
336-4856-2-ND,336-4856-1-ND,336-4856-6-ND | EFR32BG1B132F256GM32-C0R |
336-3745-ND | EFR32BG1B232F256GM48-C0 |
336-EFR32BG21B010F1024IM32-BRTR-ND,336-EFR32BG21B010F1024IM32-BRCT-ND,336-EFR32BG21B010F1024IM32-BRDKR-ND | EFR32BG21B010F1024IM32-BR |
336-EFR32FG23A010F256GM48-C-ND | EFR32FG23A010F256GM48-C |
336-5922-ND | EFR32BG13P732F512GM48-D |
336-EFR32BG13P632F512GM32-DRTR-ND,336-EFR32BG13P632F512GM32-DRCT-ND,336-EFR32BG13P632F512GM32-DRDKR-ND | EFR32BG13P632F512GM32-DR |
336-EFR32MG24A010F1536IM48-B-ND | EFR32MG24A010F1536IM48-B |
EFR32MG21A020F1024IM32-B-ND | EFR32MG21A020F1024IM32-B |
336-EFR32BG13P632F512GM48-DRTR-ND,336-EFR32BG13P632F512GM48-DRCT-ND,336-EFR32BG13P632F512GM48-DRDKR-ND | EFR32BG13P632F512GM48-DR |
336-EFR32FG23A010F512GM48-C-ND | EFR32FG23A010F512GM48-C |
336-5894-2-ND,336-5894-1-ND,336-5894-6-ND | EFR32ZG14P231F256GM32-BR |
336-EFR32MG21B020F1024IM32-BRTR-ND,336-EFR32MG21B020F1024IM32-BRCT-ND,336-EFR32MG21B020F1024IM32-BRDKR-ND | EFR32MG21B020F1024IM32-BR |
336-3750-ND | EFR32FG1P132F256GM32-C0 |
336-EFR32MG13P732F512GM48-DRTR-ND,336-EFR32MG13P732F512GM48-DRCT-ND,336-EFR32MG13P732F512GM48-DRDKR-ND | EFR32MG13P732F512GM48-DR |
336-EFR32MG13P732F512IM32-DRTR-ND,336-EFR32MG13P732F512IM32-DRCT-ND,336-EFR32MG13P732F512IM32-DRDKR-ND | EFR32MG13P732F512IM32-DR |
336-5924-ND | EFR32FG13P231F512GM48-D |
336-EFR32MG24B310F1536IM48-B-ND | EFR32MG24B310F1536IM48-B |
336-4227-ND | EFR32MG12P432F1024GM48-C |
336-EFR32MG24B010F1536IM48-B-ND | EFR32MG24B010F1536IM48-B |
336-EFR32FG13P231F512GM48-DRTR-ND,336-EFR32FG13P231F512GM48-DRCT-ND,336-EFR32FG13P231F512GM48-DRDKR-ND | EFR32FG13P231F512GM48-DR |
336-EFR32FG25B222F1920IM56-B-ND | EFR32FG25B222F1920IM56-B |
336-4222-ND | EFR32MG12P432F1024IM48-C |
336-EFR32MG12P433F1024GM48-CRTR-ND,336-EFR32MG12P433F1024GM48-CRCT-ND,336-EFR32MG12P433F1024GM48-CRDKR-ND | EFR32MG12P433F1024GM48-CR |
336-4426-ND | EFR32MG12P433F1024GM68-C |
336-4220-ND | EFR32MG12P433F1024GL125-C |
336-EFR32FG25B221F1920IM56-B-ND | EFR32FG25B221F1920IM56-B |
336-EFR32FG12P431F1024GM48-CRTR-ND,336-EFR32FG12P431F1024GM48-CRCT-ND,336-EFR32FG12P431F1024GM48-CRDKR-ND | EFR32FG12P431F1024GM48-CR |
336-4228-ND | EFR32FG12P431F1024GM48-C |
336-EFR32BG22C222F352GN32-C-ND | EFR32BG22C222F352GN32-C |
EFR32BG21A010F768IM32-B-ND | EFR32BG21A010F768IM32-B |
EFR32BG21A010F512IM32-B-ND | EFR32BG21A010F512IM32-B |
336-EFR32MG22C224F512GN32-C-ND | EFR32MG22C224F512GN32-C |
336-3744-ND | EFR32BG1B232F256GM32-C0 |
EFR32BG21A010F1024IM32-B-ND | EFR32BG21A010F1024IM32-B |
336-4857-2-ND,336-4857-1-ND,336-4857-6-ND | EFR32BG1B132F256GM48-C0R |
EFR32BG21A020F512IM32-B-ND | EFR32BG21A020F512IM32-B |
EFR32MG21A010F512IM32-B-ND | EFR32MG21A010F512IM32-B |
336-5182-2-ND,336-5182-1-ND,336-5182-6-ND | EFR32BG1B232F256GM32-C0R |
EFR32BG21A020F1024IM32-B-ND | EFR32BG21A020F1024IM32-B |
EFR32BG21A020F768IM32-B-ND | EFR32BG21A020F768IM32-B |
EFR32MG21A010F768IM32-B-ND | EFR32MG21A010F768IM32-B |
EFR32BG1B132F256GM32-C0-ND | EFR32BG1B132F256GM32-C0 |
EFR32MG21A020F512IM32-B-ND | EFR32MG21A020F512IM32-B |
336-EFR32BG21B020F1024IM32-B-ND | EFR32BG21B020F1024IM32-B |
EFR32BG13P632F512GM48-D-ND | EFR32BG13P632F512GM48-D |
336-EFR32MG21B020F512IM32-B-ND | EFR32MG21B020F512IM32-B |
336-EFR32MG21B010F1024IM32-B-ND | EFR32MG21B010F1024IM32-B |
336-EFR32ZG23B010F512IM40-B-ND | EFR32ZG23B010F512IM40-B |
336-EFR32BG21B020F1024IM32-BRTR-ND,336-EFR32BG21B020F1024IM32-BRCT-ND,336-EFR32BG21B020F1024IM32-BRDKR-ND | EFR32BG21B020F1024IM32-BR |
EFR32BG13P632F512GM32-D-ND | EFR32BG13P632F512GM32-D |
EFR32MG13P632F512GM32-D-ND | EFR32MG13P632F512GM32-D |
336-3752-ND | EFR32FG1P132F64GM32-C0 |
EFR32MG13P632F512GM48-D-ND | EFR32MG13P632F512GM48-D |
336-EFR32ZG23A010F512GM40-C-ND | EFR32ZG23A010F512GM40-C |
336-5867-2-ND,336-5867-1-ND,336-5867-6-ND | EFR32MG21A010F1024IM32-BR |
EFR32MG21A010F1024IM32-B-ND | EFR32MG21A010F1024IM32-B |
336-EFR32MG24A021F1024IM40-B-ND | EFR32MG24A021F1024IM40-B |
336-5921-ND | EFR32BG13P732F512GM32-D |
EFR32MG21A020F768IM32-B-ND | EFR32MG21A020F768IM32-B |
336-5893-ND | EFR32ZG14P231F256GM32-B |
336-EFR32BG13P732F512GM48-DRTR-ND,336-EFR32BG13P732F512GM48-DRCT-ND,336-EFR32BG13P732F512GM48-DRDKR-ND | EFR32BG13P732F512GM48-DR |
336-3756-ND | EFR32FG1V132F256GM32-C0 |
336-3714-ND | EFR32FG1V131F256GM32-C0 |
336-4414-ND | EFR32BG12P132F1024GM48-C |
336-EFR32MG21B010F1024IM32-BRTR-ND,336-EFR32MG21B010F1024IM32-BRCT-ND,336-EFR32MG21B010F1024IM32-BRDKR-ND | EFR32MG21B010F1024IM32-BR |
336-5358-ND | EFR32FG1V131F64GM32-C0 |
336-EFR32MG13P632F512GM32-DRTR-ND,336-EFR32MG13P632F512GM32-DRCT-ND,336-EFR32MG13P632F512GM32-DRDKR-ND | EFR32MG13P632F512GM32-DR |
336-5926-ND | EFR32MG13P732F512GM48-D |
336-5356-ND | EFR32FG1V131F128GM32-C0 |
336-5359-ND | EFR32FG1V131F64GM48-C0 |
336-EFR32FG25B111F1152IM56-B-ND | EFR32FG25B111F1152IM56-B |
336-3753-ND | EFR32FG1P132F64GM48-C0 |
336-4614-ND | EFR32FG1P131F64GM32-C0 |
336-4858-ND | EFR32FG1V131F128GM48-C0 |
336-5350-ND | EFR32FG1P131F128GM32-C0 |
336-EFR32MG24B120F1536IM48-B-ND | EFR32MG24B120F1536IM48-B |
EFR32FG13P232F512GM32-D-ND | EFR32FG13P232F512GM32-D |
336-5779-ND | EFR32FG14P231F128GM32-B |
336-5351-ND | EFR32FG1P131F128GM48-C0 |
336-3749-ND | EFR32FG1P132F128GM48-C0 |
336-4415-ND | EFR32MG12P232F1024GM48-C |
336-3715-ND | EFR32FG1V131F256GM48-C0 |
336-3757-ND | EFR32FG1V132F256GM48-C0 |
336-EFR32FG25A121F1152IM56-B-ND | EFR32FG25A121F1152IM56-B |
336-5927-ND | EFR32MG13P733F512GM48-D |
336-EFR32FG1P131F256GM32-C0RTR-ND,336-EFR32FG1P131F256GM32-C0RCT-ND,336-EFR32FG1P131F256GM32-C0RDKR-ND | EFR32FG1P131F256GM32-C0R |
336-EFR32FG25A111F1152IM56-B-ND | EFR32FG25A111F1152IM56-B |
336-EFR32MG12P132F1024GM48-CRTR-ND,336-EFR32MG12P132F1024GM48-CRCT-ND,336-EFR32MG12P132F1024GM48-CRDKR-ND | EFR32MG12P132F1024GM48-CR |
336-3751-ND | EFR32FG1P132F256GM48-C0 |
336-5360-ND | EFR32MG12P132F1024GM48-C |
336-3712-ND | EFR32FG1P131F256GM48-C0 |
336-5923-ND | EFR32FG13P231F512GM32-D |
336-5784-ND | EFR32BG12P132F1024GL125-C |
336-EFR32FG25B121F1152IM56-B-ND | EFR32FG25B121F1152IM56-B |
336-4178-ND | EFR32FG14P231F256GM48-B |
336-4170-ND | EFR32FG14P231F256IM32-B |
336-EFR32MG24A020F1536IM40-B-ND | EFR32MG24A020F1536IM40-B |
336-EFR32FG25A211F1920IM56-B-ND | EFR32FG25A211F1920IM56-B |
336-4224-ND | EFR32BG12P432F1024GL125-C |
336-5095-2-ND,336-5095-1-ND,336-5095-6-ND | EFR32BG12P232F1024GM68-CR |
336-EFR32FG25B212F1920IM56-B-ND | EFR32FG25B212F1920IM56-B |
336-6196-ND | EFR32BG12P433F1024GM48-C |
336-EFR32MG12P332F1024GM48-CRTR-ND,336-EFR32MG12P332F1024GM48-CRCT-ND,336-EFR32MG12P332F1024GM48-CRDKR-ND | EFR32MG12P332F1024GM48-CR |
336-5790-ND | EFR32BG12P332F1024GM48-C |
336-5349-ND | EFR32FG14P231F128GM48-B |
336-EFR32FG14P231F256GM32-BRTR-ND,336-EFR32FG14P231F256GM32-BRCT-ND,336-EFR32FG14P231F256GM32-BRDKR-ND | EFR32FG14P231F256GM32-BR |
336-4179-ND | EFR32FG14P231F256GM32-B |
EFR32BG12P433F1024GL125-C-ND | EFR32BG12P433F1024GL125-C |
336-EFR32FG14P231F256GM48-BRTR-ND,336-EFR32FG14P231F256GM48-BRCT-ND,336-EFR32FG14P231F256GM48-BRDKR-ND | EFR32FG14P231F256GM48-BR |
336-5794-ND | EFR32MG12P433F1024IM48-C |
336-5792-ND | EFR32BG12P332F1024GL125-C |
336-EFR32MG12P432F1024GM48-CRTR-ND,336-EFR32MG12P432F1024GM48-CRCT-ND,336-EFR32MG12P432F1024GM48-CRDKR-ND | EFR32MG12P432F1024GM48-CR |
336-EFR32MG12P432F1024IM48-CRTR-ND,336-EFR32MG12P432F1024IM48-CRCT-ND,336-EFR32MG12P432F1024IM48-CRDKR-ND | EFR32MG12P432F1024IM48-CR |
336-4429-ND | EFR32FG12P431F1024GM68-C |
336-6197-2-ND,336-6197-1-ND,336-6197-6-ND | EFR32BG12P433F1024GM48-CR |
336-EFR32FG12P232F1024GM48-CRTR-ND,336-EFR32FG12P232F1024GM48-CRCT-ND,336-EFR32FG12P232F1024GM48-CRDKR-ND | EFR32FG12P232F1024GM48-CR |
336-5348-ND | EFR32FG12P433F1024GM48-C |
336-5097-2-ND,336-5097-1-ND,336-5097-6-ND | EFR32BG12P433F1024GM68-CR |
336-EFR32FG12P231F1024GM48-CRTR-ND,336-EFR32FG12P231F1024GM48-CRCT-ND,336-EFR32FG12P231F1024GM48-CRDKR-ND | EFR32FG12P231F1024GM48-CR |
336-5347-ND | EFR32FG12P231F1024GM48-C |
336-5102-ND | EFR32BG12P433F1024GM68-C |
336-EFR32MG12P433F1024GL125-CRTR-ND,336-EFR32MG12P433F1024GL125-CRCT-ND,336-EFR32MG12P433F1024GL125-CRDKR-ND | EFR32MG12P433F1024GL125-CR |
336-EFR32FG25A221F1920IM56-B-ND | EFR32FG25A221F1920IM56-B |
336-EFR32FG12P231F1024GM68-CRTR-ND,336-EFR32FG12P231F1024GM68-CRCT-ND,336-EFR32FG12P231F1024GM68-CRDKR-ND | EFR32FG12P231F1024GM68-CR |
336-4229-ND | EFR32FG12P432F1024GM48-C |
336-EFR32FG12P433F1024GM48-CRTR-ND,336-EFR32FG12P433F1024GM48-CRCT-ND,336-EFR32FG12P433F1024GM48-CRDKR-ND | EFR32FG12P433F1024GM48-CR |
336-EFR32BG22E224F512IM32-C-ND | EFR32BG22E224F512IM32-C |
336-EFR32BG27C230F768IM32-B-ND | EFR32BG27C230F768IM32-B |
336-EFR32BG27C230F768IM40-B-ND | EFR32BG27C230F768IM40-B |
336-EFR32MG27C230F768IM32-B-ND | EFR32MG27C230F768IM32-B |
336-EFR32MG27C230F768IM40-B-ND | EFR32MG27C230F768IM40-B |
336-EFR32SG23B020F512IM40-C-ND | EFR32SG23B020F512IM40-C |
336-EFR32MR21A020F512IM32-C-ND | EFR32MR21A020F512IM32-C |
336-EFR32BG21A010F1024IM32-D-ND | EFR32BG21A010F1024IM32-D |
336-EFR32BG21B010F1024IM32-D-ND | EFR32BG21B010F1024IM32-D |
336-EFR32BG21A020F1024IM32-D-ND | EFR32BG21A020F1024IM32-D |
336-EFR32BG21B020F1024IM32-D-ND | EFR32BG21B020F1024IM32-D |
336-EFR32SG28B320F1024IM48-A-ND | EFR32SG28B320F1024IM48-A |
336-EFR32SG28B320F1024IM68-A-ND | EFR32SG28B320F1024IM68-A |
336-EFR32MG21A010F1024IM32-D-ND | EFR32MG21A010F1024IM32-D |
336-EFR32FG28B310F1024IM68-A-ND | EFR32FG28B310F1024IM68-A |
336-EFR32SG28B322F1024IM68-A-ND | EFR32SG28B322F1024IM68-A |
336-EFR32FG28B320F1024IM68-A-ND | EFR32FG28B320F1024IM68-A |
336-EFR32ZG28B310F1024IM68-A-ND | EFR32ZG28B310F1024IM68-A |
336-EFR32MG21B010F1024IM32-D-ND | EFR32MG21B010F1024IM32-D |
336-EFR32FG28B312F1024IM68-A-ND | EFR32FG28B312F1024IM68-A |
336-EFR32ZG28B312F1024IM68-A-ND | EFR32ZG28B312F1024IM68-A |
336-EFR32BG26B410F3200IM48-B-ND | EFR32BG26B410F3200IM48-B |
336-EFR32MG21A020F1024IM32-D-ND | EFR32MG21A020F1024IM32-D |
336-EFR32ZG28B322F1024IM68-A-ND | EFR32ZG28B322F1024IM68-A |
336-EFR32FG28A120F1024GM48-ARTR-ND,336-EFR32FG28A120F1024GM48-ARCT-ND,336-EFR32FG28A120F1024GM48-ARDKR-ND | EFR32FG28A120F1024GM48-AR |
336-EFR32FG28A120F1024GM48-A-ND | EFR32FG28A120F1024GM48-A |
336-EFR32BG26B510F3200IM48-B-ND | EFR32BG26B510F3200IM48-B |
336-EFR32BG26B420F3200IM48-B-ND | EFR32BG26B420F3200IM48-B |
336-EFR32BG26B510F3200IM68-B-ND | EFR32BG26B510F3200IM68-B |
336-EFR32MG21B020F1024IM32-D-ND | EFR32MG21B020F1024IM32-D |
336-EFR32BG26B510F3200IL136-B-ND | EFR32BG26B510F3200IL136-B |
336-EFR32MG26B410F3200IM48-B-ND | EFR32MG26B410F3200IM48-B |
336-EFR32MG26B410F3200IM68-B-ND | EFR32MG26B410F3200IM68-B |
336-EFR32SG28B322F1024IM48-A-ND | EFR32SG28B322F1024IM48-A |
336-EFR32FG28A122F1024GM48-A-ND | EFR32FG28A122F1024GM48-A |
336-EFR32ZG28B310F1024IM48-A-ND | EFR32ZG28B310F1024IM48-A |
336-EFR32MG26B510F3200IM48-B-ND | EFR32MG26B510F3200IM48-B |
336-EFR32FG28A112F1024GM68-A-ND | EFR32FG28A112F1024GM68-A |
336-EFR32MG26B420F3200IM48-B-ND | EFR32MG26B420F3200IM48-B |
336-EFR32MG26B510F3200IM68-B-ND | EFR32MG26B510F3200IM68-B |
336-EFR32MG26B420F3200IM68-B-ND | EFR32MG26B420F3200IM68-B |
336-EFR32MG26B510F3200IL136-B-ND | EFR32MG26B510F3200IL136-B |
336-EFR32ZG28B320F1024IM48-A-ND | EFR32ZG28B320F1024IM48-A |
336-EFR32MG24A420F1536IM40-B-ND | EFR32MG24A420F1536IM40-B |
336-EFR32ZG28B312F1024IM48-A-ND | EFR32ZG28B312F1024IM48-A |
336-EFR32MG26B520F3200IM48-B-ND | EFR32MG26B520F3200IM48-B |
336-EFR32MG26B520F3200IM68-B-ND | EFR32MG26B520F3200IM68-B |
336-EFR32ZG28B320F1024IM68-A-ND | EFR32ZG28B320F1024IM68-A |
336-EFR32ZG28B322F1024IM48-A-ND | EFR32ZG28B322F1024IM48-A |
336-EFR32BG22C112F352GM32-CRTR-ND | EFR32BG22C112F352GM32-CR |
2832-EFR32BG22C224F512GN32-CRTR-ND,336-EFR32BG22C224F512GN32-CRTR-ND | EFR32BG22C224F512GN32-CR |
336-EFR32BG22C224F512GM40-CRTR-ND | EFR32BG22C224F512GM40-CR |
336-EFR32FG22C121F512GM40-CRTB-ND | EFR32FG22C121F512GM40-CR |
336-EFR32MG22C224F512IM32-CRTB-ND | EFR32MG22C224F512IM32-CR |
336-EFR32MG22C224F512IM40-CRTB-ND | EFR32MG22C224F512IM40-CR |
2832-EFR32BG21B020F512IM32-BR-ND,336-EFR32BG21B020F512IM32-BRTR-ND | EFR32BG21B020F512IM32-BR |
336-EFR32BG22C224F512GM32-CRCT-ND,336-EFR32BG22C224F512GM32-CRTB-ND | EFR32BG22C224F512GM32-CR |
336-EFR32MG22C224F512GN32-CRTB-ND,336-EFR32MG22C224F512GN32-CRCT-ND,336-EFR32MG22C224F512GN32-CRDKR-ND | EFR32MG22C224F512GN32-CR |
2832-EFR32BG1P332F256GM32-C0R-ND,EFR32BG1P332F256GM32-C0R-ND | EFR32BG1P332F256GM32-C0R |
2832-EFR32MG24A010F1536IM40-BR-ND,336-EFR32MG24A010F1536IM40-BRTR-ND | EFR32MG24A010F1536IM40-BR |
EFR32FG1V032F256GM32-C0R-ND | EFR32FG1V032F256GM32-C0R |
336-3758-ND | EFR32FG1V132F32GM32-C0 |
336-EFR32FG23A010F256GM48-CRTR-ND,336-EFR32FG23A010F256GM48-CRCT-ND,336-EFR32FG23A010F256GM48-CRDKR-ND | EFR32FG23A010F256GM48-CR |
2832-EFR32MG24A020F1536IM48-BR-ND,336-EFR32MG24A020F1536IM48-BRTR-ND | EFR32MG24A020F1536IM48-BR |
2832-EFR32MG24B010F1536IM40-BR-ND,336-EFR32MG24B010F1536IM40-BRTR-ND | EFR32MG24B010F1536IM40-BR |
336-EFR32BG21A020F768IM32-BRTR-ND,336-EFR32BG21A020F768IM32-BRCT-ND,336-EFR32BG21A020F768IM32-BRDKR-ND | EFR32BG21A020F768IM32-BR |
2832-EFR32MG24A020F1536IM40-BRTR-ND,336-EFR32MG24A020F1536IM40-BRTR-ND | EFR32MG24A020F1536IM40-BR |
2832-EFR32BG12P432F1024GL125-CRTR-ND,EFR32BG12P432F1024GL125-CR-ND | EFR32BG12P432F1024GL125-CR |
EFR32FG1P133F256GM48-C0R-ND | EFR32FG1P133F256GM48-C0R |
2832-EFR32FG14P231F256IM32-BR-ND,EFR32FG14P231F256IM32-BR-ND | EFR32FG14P231F256IM32-BR |
336-3761-ND | EFR32FG1V132F64GM48-C0 |
336-3759-ND | EFR32FG1V132F32GM48-C0 |
336-EFR32FG25A111F1152IM56-BRTR-ND,336-EFR32FG25A111F1152IM56-BRCT-ND,336-EFR32FG25A111F1152IM56-BRDKR-ND | EFR32FG25A111F1152IM56-BR |
336-4615-ND | EFR32FG1V131F32GM32-C0 |
2832-EFR32FG12P432F1024GM48-CR-ND,EFR32FG12P432F1024GM48-CR-ND | EFR32FG12P432F1024GM48-CR |
336-3760-ND | EFR32FG1V132F64GM32-C0 |
336-EFR32FG25B111F1152IM56-BRTR-ND,336-EFR32FG25B111F1152IM56-BRCT-ND,336-EFR32FG25B111F1152IM56-BRDKR-ND | EFR32FG25B111F1152IM56-BR |
2832-EFR32FG12P431F1024GL125-CR-ND,EFR32FG12P431F1024GL125-CR-ND | EFR32FG12P431F1024GL125-CR |
336-3748-ND | EFR32FG1P132F128GM32-C0 |
336-EFR32FG25A121F1152IM56-BRTR-ND,336-EFR32FG25A121F1152IM56-BRCT-ND,336-EFR32FG25A121F1152IM56-BRDKR-ND | EFR32FG25A121F1152IM56-BR |
336-EFR32FG25B121F1152IM56-BRTR-ND,336-EFR32FG25B121F1152IM56-BRCT-ND,336-EFR32FG25B121F1152IM56-BRDKR-ND | EFR32FG25B121F1152IM56-BR |
336-EFR32FG25A211F1920IM56-BRTR-ND,336-EFR32FG25A211F1920IM56-BRCT-ND,336-EFR32FG25A211F1920IM56-BRDKR-ND | EFR32FG25A211F1920IM56-BR |
336-4428-ND | EFR32MG12P432F1024GM68-C |
336-EFR32FG25B211F1920IM56-BRTR-ND,336-EFR32FG25B211F1920IM56-BRCT-ND,336-EFR32FG25B211F1920IM56-BRDKR-ND | EFR32FG25B211F1920IM56-BR |
336-EFR32FG25B212F1920IM56-BRTR-ND,336-EFR32FG25B212F1920IM56-BRCT-ND,336-EFR32FG25B212F1920IM56-BRDKR-ND | EFR32FG25B212F1920IM56-BR |
336-EFR32FG25A221F1920IM56-BRTR-ND,336-EFR32FG25A221F1920IM56-BRCT-ND,336-EFR32FG25A221F1920IM56-BRDKR-ND | EFR32FG25A221F1920IM56-BR |
336-EFR32FG25B221F1920IM56-BRTR-ND,336-EFR32FG25B221F1920IM56-BRCT-ND,336-EFR32FG25B221F1920IM56-BRDKR-ND | EFR32FG25B221F1920IM56-BR |
336-EFR32FG25B222F1920IM56-BRTR-ND,336-EFR32FG25B222F1920IM56-BRCT-ND,336-EFR32FG25B222F1920IM56-BRDKR-ND | EFR32FG25B222F1920IM56-BR |
336-4226-ND | EFR32FG12P432F1024GL125-C |
336-EFR32BG21B010F1024IM32-B-ND | EFR32BG21B010F1024IM32-B |
EFR32BG1P332F256GM32-C0-ND | EFR32BG1P332F256GM32-C0 |
EFR32BG1P232F256GM48-C0-ND | EFR32BG1P232F256GM48-C0 |
336-3709-ND | EFR32BG1P333F256GM48-C0 |
336-5785-ND | EFR32FG12P232F1024GM48-C |
336-EFR32BG22C224F512GM32-C-ND | EFR32BG22C224F512GM32-C |
336-EFR32BG22E224F512IM40-C-ND | EFR32BG22E224F512IM40-C |
336-EFR32FG22E121F512IM32-C-ND | EFR32FG22E121F512IM32-C |
336-EFR32MG27C140F768IM32-B-ND | EFR32MG27C140F768IM32-B |
336-EFR32FG22E121F512IM40-C-ND | EFR32FG22E121F512IM40-C |
336-3924-ND | EFR32FG12P432F1024GL125-B |
336-4225-ND | EFR32FG12P431F1024GL125-C |
336-EFR32FG28B310F1024IM48-A-ND | EFR32FG28B310F1024IM48-A |
336-EFR32MG24B020F1536IM40-B-ND | EFR32MG24B020F1536IM40-B |
336-EFR32FG28B312F1024IM48-A-ND | EFR32FG28B312F1024IM48-A |
336-5925-ND | EFR32MG13P732F512GM32-D |
336-EFR32FG25B211F1920IM56-B-ND | EFR32FG25B211F1920IM56-B |
336-EFR32FG22C121F512GM32-C-ND | EFR32FG22C121F512GM32-C |
336-EFR32MG21B020F1024IM32-B-ND | EFR32MG21B020F1024IM32-B |
336-3711-ND | EFR32FG1P131F256GM32-C0 |
336-5791-ND | EFR32BG12P332F1024GL125-B |
336-3713-ND | EFR32FG1P133F256GM48-C0 |
336-5342-ND | EFR32BG12P433F1024GL125-B |
336-4223-ND | EFR32BG12P432F1024GM48-C |
336-5783-ND | EFR32FG14P233F256GM48-B |
336-4221-ND | EFR32MG12P432F1024GL125-C |
336-4427-ND | EFR32FG12P433F1024GM68-C |
336-EFR32BG22L122F352GM32-C-ND | EFR32BG22L122F352GM32-C |
336-EFR32BG24L010F768IM40-B-ND | EFR32BG24L010F768IM40-B |
336-EFR32BG24L210F768IM40-B-ND | EFR32BG24L210F768IM40-B |
336-EFR32BG24B310F1536IJ42-BRTR-ND,336-EFR32BG24B310F1536IJ42-BRCT-ND,336-EFR32BG24B310F1536IJ42-BRDKR-ND | EFR32BG24B310F1536IJ42-BR |
336-EFR32BG22L122F352GM32-CRTR-ND | EFR32BG22L122F352GM32-CR |
336-EFR32BG22C222F352GM32-CRTR-ND | EFR32BG22C222F352GM32-CR |
336-EFR32BG22C222F352GN32-CRTB-ND | EFR32BG22C222F352GN32-CR |
336-EFR32BG22C222F352GM40-CRTB-ND | EFR32BG22C222F352GM40-CR |
336-EFR32BG22C224F512IM32-CRTR-ND | EFR32BG22C224F512IM32-CR |
336-EFR32FG22C121F512GM32-CRTB-ND | EFR32FG22C121F512GM32-CR |
336-EFR32BG22C224F512IM40-CRTB-ND | EFR32BG22C224F512IM40-CR |
336-EFR32BG22E224F512IM32-CRTR-ND | EFR32BG22E224F512IM32-CR |
336-EFR32BG27C140F768IM32-BRTR-ND | EFR32BG27C140F768IM32-BR |
336-EFR32BG27C140F768IM40-BRTR-ND | EFR32BG27C140F768IM40-BR |
336-EFR32BG27C230F768IM32-BRTR-ND | EFR32BG27C230F768IM32-BR |
336-EFR32BG22E224F512IM40-CRTR-ND | EFR32BG22E224F512IM40-CR |
336-EFR32BG27C320F768GJ39-BRTR-ND | EFR32BG27C320F768GJ39-BR |
336-EFR32BG27C230F768IM40-BRTR-ND | EFR32BG27C230F768IM40-BR |
336-EFR32FG22E121F512IM32-CRTR-ND | EFR32FG22E121F512IM32-CR |
EFR32BG21A010F512IM32-BR-ND | EFR32BG21A010F512IM32-BR |
336-EFR32FG22E121F512IM40-CRTR-ND | EFR32FG22E121F512IM40-CR |
336-EFR32BG27C320F768IJ39-BRTR-ND | EFR32BG27C320F768IJ39-BR |
336-EFR32BG24L010F768IM40-BRTR-ND | EFR32BG24L010F768IM40-BR |
336-EFR32BG21A010F512IM32-DRTR-ND | EFR32BG21A010F512IM32-DR |
336-EFR32BG21A010F512IM32-D-ND | EFR32BG21A010F512IM32-D |
EFR32BG21A010F768IM32-BR-ND | EFR32BG21A010F768IM32-BR |
336-EFR32BG21B010F512IM32-B-ND | EFR32BG21B010F512IM32-B |
336-EFR32BG21B010F512IM32-BRTR-ND | EFR32BG21B010F512IM32-BR |
336-EFR32BG24A010F1024IM40-BRTR-ND | EFR32BG24A010F1024IM40-BR |
336-EFR32BG24L210F768IM40-BRTR-ND | EFR32BG24L210F768IM40-BR |
336-EFR32BG24A010F1024IM48-BRTR-ND | EFR32BG24A010F1024IM48-BR |
336-EFR32BG24A010F1024IM48-B-ND | EFR32BG24A010F1024IM48-B |
336-EFR32MG27C140F768IM32-BRTR-ND | EFR32MG27C140F768IM32-BR |
EFR32BG21A020F512IM32-BR-ND | EFR32BG21A020F512IM32-BR |
336-EFR32MG27C140F768IM40-BRTR-ND | EFR32MG27C140F768IM40-BR |
336-EFR32BG24A020F1024IM40-BRTR-ND | EFR32BG24A020F1024IM40-BR |
336-EFR32MG27C230F768IM32-BRTR-ND | EFR32MG27C230F768IM32-BR |
336-EFR32BG24A020F1024IM48-BRTR-ND | EFR32BG24A020F1024IM48-BR |
336-EFR32MG27C230F768IM40-BRTR-ND | EFR32MG27C230F768IM40-BR |
336-EFR32BG21B010F768IM32-B-ND | EFR32BG21B010F768IM32-B |
336-EFR32BG21B010F768IM32-BRTR-ND | EFR32BG21B010F768IM32-BR |
336-EFR32BG21A010F768IM32-DRTR-ND | EFR32BG21A010F768IM32-DR |
336-EFR32BG21B010F512IM32-DRTR-ND | EFR32BG21B010F512IM32-DR |
336-EFR32BG21B010F512IM32-D-ND | EFR32BG21B010F512IM32-D |
336-EFR32BG21A010F768IM32-D-ND | EFR32BG21A010F768IM32-D |
EFR32BG1B132F256GM48-C0-ND | EFR32BG1B132F256GM48-C0 |
336-EFR32BG24B210F1024IM48-BRTR-ND | EFR32BG24B210F1024IM48-BR |
EFR32BG1B232F256GM48-C0R-ND | EFR32BG1B232F256GM48-C0R |
EFR32BG1B132F256IM32-C0-ND | EFR32BG1B132F256IM32-C0 |
EFR32BG1B132F256IM32-C0R-ND | EFR32BG1B132F256IM32-C0R |
336-EFR32BG21B020F512IM32-B-ND | EFR32BG21B020F512IM32-B |
336-EFR32BG21A020F512IM32-DRTR-ND | EFR32BG21A020F512IM32-DR |
336-EFR32BG21A020F512IM32-D-ND | EFR32BG21A020F512IM32-D |
336-EFR32FG23A010F256GM40-CRTR-ND | EFR32FG23A010F256GM40-CR |
336-EFR32BG24B220F1024IM48-BRTR-ND | EFR32BG24B220F1024IM48-BR |
336-EFR32SG23B020F512IM40-CRTR-ND | EFR32SG23B020F512IM40-CR |
336-EFR32BG21B010F768IM32-DRTR-ND | EFR32BG21B010F768IM32-DR |
336-EFR32BG21B010F768IM32-D-ND | EFR32BG21B010F768IM32-D |
336-EFR32FG23A020F128GM40-CRTR-ND | EFR32FG23A020F128GM40-CR |
336-EFR32FG23A020F128GM40-C-ND | EFR32FG23A020F128GM40-C |
336-EFR32FG23B010F128GM40-CRTR-ND | EFR32FG23B010F128GM40-CR |
EFR32MG21A010F512IM32-BR-ND | EFR32MG21A010F512IM32-BR |
336-EFR32MR21A020F512IM32-CRTR-ND | EFR32MR21A020F512IM32-CR |
336-EFR32BG21A010F1024IM32-DRTR-ND | EFR32BG21A010F1024IM32-DR |
336-EFR32BG21B020F768IM32-BRTR-ND | EFR32BG21B020F768IM32-BR |
336-EFR32BG21B020F768IM32-B-ND | EFR32BG21B020F768IM32-B |
336-EFR32FG23A020F256GM40-CRTR-ND | EFR32FG23A020F256GM40-CR |
336-EFR32FG23A020F256GM40-C-ND | EFR32FG23A020F256GM40-C |
336-EFR32FG23B010F128GM40-C-ND | EFR32FG23B010F128GM40-C |
336-EFR32BG21B020F512IM32-DRTR-ND | EFR32BG21B020F512IM32-DR |
336-EFR32BG21A020F768IM32-DRTR-ND | EFR32BG21A020F768IM32-DR |
336-EFR32BG21A020F768IM32-D-ND | EFR32BG21A020F768IM32-D |
336-EFR32BG21B020F512IM32-D-ND | EFR32BG21B020F512IM32-D |
336-EFR32FG23A020F256GM48-CRTR-ND | EFR32FG23A020F256GM48-CR |
336-EFR32FG23A020F256GM48-C-ND | EFR32FG23A020F256GM48-C |
EFR32BG13P532F512GM32-D-ND | EFR32BG13P532F512GM32-D |
EFR32BG13P532F512GM32-DR-ND | EFR32BG13P532F512GM32-DR |
336-EFR32FG23B020F128GM40-CRTR-ND | EFR32FG23B020F128GM40-CR |
EFR32MG21A010F768IM32-BR-ND | EFR32MG21A010F768IM32-BR |
336-EFR32MG21B010F512IM32-BRTR-ND | EFR32MG21B010F512IM32-BR |
336-EFR32MG21B010F512IM32-B-ND | EFR32MG21B010F512IM32-B |
336-5344-ND | EFR32BG1P232F256GM32-C0 |
EFR32BG1P232F256GM32-C0R-ND | EFR32BG1P232F256GM32-C0R |
EFR32BG13P532F512GM48-DR-ND | EFR32BG13P532F512GM48-DR |
336-EFR32FG23A010F512GM40-CRTR-ND | EFR32FG23A010F512GM40-CR |
336-EFR32FG23B020F128GM40-C-ND | EFR32FG23B020F128GM40-C |
336-EFR32FG23A010F512GM40-C-ND | EFR32FG23A010F512GM40-C |
336-EFR32BG21B010F1024IM32-DRTR-ND | EFR32BG21B010F1024IM32-DR |
336-EFR32MG21A010F512IM32-DRTR-ND | EFR32MG21A010F512IM32-DR |
336-EFR32MG21A010F512IM32-D-ND | EFR32MG21A010F512IM32-D |
336-EFR32MG24A010F1024IM40-B-ND | EFR32MG24A010F1024IM40-B |
336-EFR32MG24A010F1024IM40-BRTR-ND | EFR32MG24A010F1024IM40-BR |
336-EFR32BG21B020F768IM32-DRTR-ND | EFR32BG21B020F768IM32-DR |
336-EFR32BG21B020F768IM32-D-ND | EFR32BG21B020F768IM32-D |
EFR32BG1P232F256GM48-C0R-ND | EFR32BG1P232F256GM48-C0R |
336-EFR32BG24B110F1536IM48-BRTR-ND | EFR32BG24B110F1536IM48-BR |
EFR32BG13P532F512GM48-D-ND | EFR32BG13P532F512GM48-D |
336-EFR32FG23A011F512GM40-CRTR-ND | EFR32FG23A011F512GM40-CR |
336-EFR32FG23A010F512GM48-CRTR-ND | EFR32FG23A010F512GM48-CR |
336-EFR32FG23A011F512GM40-C-ND | EFR32FG23A011F512GM40-C |
EFR32MG21A020F512IM32-BR-ND | EFR32MG21A020F512IM32-BR |
336-EFR32MG24A010F1024IM48-B-ND | EFR32MG24A010F1024IM48-B |
336-EFR32BG26B311F1024IM68-BRTR-ND | EFR32BG26B311F1024IM68-BR |
336-EFR32BG26B311F1024IL136-BRTR-ND | EFR32BG26B311F1024IL136-BR |
336-EFR32MG21B010F768IM32-B-ND | EFR32MG21B010F768IM32-B |
336-EFR32MG21B010F768IM32-BRTR-ND | EFR32MG21B010F768IM32-BR |
EFR32BG1P232F256IM32-C0-ND | EFR32BG1P232F256IM32-C0 |
EFR32BG1P232F256IM32-C0R-ND | EFR32BG1P232F256IM32-C0R |
336-EFR32BG26B311F1024IM68-B-ND | EFR32BG26B311F1024IM68-B |
336-EFR32FG23A020F512GM40-CRTR-ND | EFR32FG23A020F512GM40-CR |
336-EFR32BG21A020F1024IM32-DRTR-ND | EFR32BG21A020F1024IM32-DR |
EFR32BG1B232F256IM32-C0-ND | EFR32BG1B232F256IM32-C0 |
EFR32BG1B232F256IM32-C0R-ND | EFR32BG1B232F256IM32-C0R |
336-EFR32FG23A020F512GM40-C-ND | EFR32FG23A020F512GM40-C |
336-EFR32BG26B311F1024IL136-B-ND | EFR32BG26B311F1024IL136-B |
336-EFR32FG23B010F512IM40-CRTR-ND | EFR32FG23B010F512IM40-CR |
336-EFR32FG23B010F512IM40-C-ND | EFR32FG23B010F512IM40-C |
EFR32BG1P232F256IM48-C0R-ND | EFR32BG1P232F256IM48-C0R |
336-EFR32MG21A010F768IM32-DRTR-ND | EFR32MG21A010F768IM32-DR |
336-EFR32MG21B010F512IM32-DRTR-ND | EFR32MG21B010F512IM32-DR |
336-EFR32MG21A010F768IM32-D-ND | EFR32MG21A010F768IM32-D |
336-EFR32MG21B010F512IM32-D-ND | EFR32MG21B010F512IM32-D |
EFR32BG1P332F256GM48-C0R-ND | EFR32BG1P332F256GM48-C0R |
336-EFR32MG24A020F1024IM40-BRTR-ND | EFR32MG24A020F1024IM40-BR |
336-EFR32MG24A010F1024IM48-BRTR-ND | EFR32MG24A010F1024IM48-BR |
336-EFR32FG23A021F512GM40-CRTR-ND | EFR32FG23A021F512GM40-CR |
336-EFR32FG23A020F512GM48-CRTR-ND | EFR32FG23A020F512GM48-CR |
336-EFR32FG23A020F512GM48-C-ND | EFR32FG23A020F512GM48-C |
336-EFR32FG23A021F512GM40-C-ND | EFR32FG23A021F512GM40-C |
EFR32BG13P632F512IM32-D-ND | EFR32BG13P632F512IM32-D |
EFR32BG13P632F512IM32-DR-ND | EFR32BG13P632F512IM32-DR |
336-EFR32MG24A021F1024IM40-BRTR-ND | EFR32MG24A021F1024IM40-BR |
336-EFR32BG26B321F1024IM68-BRTR-ND | EFR32BG26B321F1024IM68-BR |
EFR32BG13P732F512GM32-DR-ND | EFR32BG13P732F512GM32-DR |
336-EFR32FG23B010F512IM48-CRTR-ND | EFR32FG23B010F512IM48-CR |
336-EFR32FG23B010F512IM48-C-ND | EFR32FG23B010F512IM48-C |
EFR32MG21A020F768IM32-BR-ND | EFR32MG21A020F768IM32-BR |
336-EFR32MG21B020F512IM32-BRTR-ND | EFR32MG21B020F512IM32-BR |
336-EFR32MG24A020F1024IM48-BRTR-ND | EFR32MG24A020F1024IM48-BR |
336-EFR32MG24A020F1024IM48-B-ND | EFR32MG24A020F1024IM48-B |
EFR32BG1P232F256IM48-C0-ND | EFR32BG1P232F256IM48-C0 |
336-EFR32BG26B311F2048IM48-BRTR-ND | EFR32BG26B311F2048IM48-BR |
336-EFR32BG26B311F2048IM48-B-ND | EFR32BG26B311F2048IM48-B |
336-5345-ND | EFR32BG1P332F256GM48-C0 |
EFR32FG1V032F128GM32-C0R-ND | EFR32FG1V032F128GM32-C0R |
336-5355-ND | EFR32FG1V032F128GM32-C0 |
336-EFR32BG26B311F2048IM68-BRTR-ND | EFR32BG26B311F2048IM68-BR |
EFR32BG13P632F512IM48-DR-ND | EFR32BG13P632F512IM48-DR |
336-EFR32BG26B321F1024IM68-B-ND | EFR32BG26B321F1024IM68-B |
336-EFR32MG21A020F512IM32-DRTR-ND | EFR32MG21A020F512IM32-DR |
336-EFR32BG21B020F1024IM32-DRTR-ND | EFR32BG21B020F1024IM32-DR |
336-EFR32MG21A020F512IM32-D-ND | EFR32MG21A020F512IM32-D |
336-EFR32FG23B020F512IM40-CRTR-ND | EFR32FG23B020F512IM40-CR |
336-EFR32MG24A110F1024IM48-B-ND | EFR32MG24A110F1024IM48-B |
336-EFR32MG24A110F1024IM48-BRTR-ND | EFR32MG24A110F1024IM48-BR |
336-EFR32FG23B020F512IM40-C-ND | EFR32FG23B020F512IM40-C |
336-EFR32BG26B311F2048IL136-BRTR-ND | EFR32BG26B311F2048IL136-BR |
336-EFR32MG24A020F1024IM40-B-ND | EFR32MG24A020F1024IM40-B |
EFR32BG12P132F1024GL125-BR-ND | EFR32BG12P132F1024GL125-BR |
336-EFR32MG21B010F768IM32-DRTR-ND | EFR32MG21B010F768IM32-DR |
336-EFR32MG21B010F768IM32-D-ND | EFR32MG21B010F768IM32-D |
EFR32FG1V131F32GM32-C0R-ND | EFR32FG1V131F32GM32-C0R |
336-EFR32FG23B021F512IM40-CRTR-ND | EFR32FG23B021F512IM40-CR |
336-EFR32FG23B021F512IM40-C-ND | EFR32FG23B021F512IM40-C |
336-EFR32BG26B311F2048IM68-B-ND | EFR32BG26B311F2048IM68-B |
EFR32FG1V132F32GM32-C0R-ND | EFR32FG1V132F32GM32-C0R |
EFR32BG13P632F512IM48-D-ND | EFR32BG13P632F512IM48-D |
336-EFR32FG23B020F512IM48-CRTR-ND | EFR32FG23B020F512IM48-CR |
336-EFR32FG23B020F512IM48-C-ND | EFR32FG23B020F512IM48-C |
336-EFR32MG21B020F768IM32-B-ND | EFR32MG21B020F768IM32-B |
336-EFR32MG21B020F768IM32-BRTR-ND | EFR32MG21B020F768IM32-BR |
336-EFR32BG26B311F2048IL136-B-ND | EFR32BG26B311F2048IL136-B |
336-EFR32ZG23A010F512GM40-CRTR-ND | EFR32ZG23A010F512GM40-CR |
336-EFR32ZG23A010F512GM48-CRTR-ND | EFR32ZG23A010F512GM48-CR |
336-EFR32BG26B321F2048IM48-BRTR-ND | EFR32BG26B321F2048IM48-BR |
336-EFR32MG26B211F2048IM68-BRTR-ND | EFR32MG26B211F2048IM68-BR |
336-EFR32ZG23A010F512GM48-C-ND | EFR32ZG23A010F512GM48-C |
336-EFR32BG26B321F2048IM48-B-ND | EFR32BG26B321F2048IM48-B |
336-EFR32FG23B021F512IM48-CRTR-ND | EFR32FG23B021F512IM48-CR |
336-EFR32FG23B021F512IM48-C-ND | EFR32FG23B021F512IM48-C |
EFR32FG1V131F64GM32-C0R-ND | EFR32FG1V131F64GM32-C0R |
336-EFR32FG28A010F1024GM48-ARTR-ND | EFR32FG28A010F1024GM48-AR |
336-EFR32BG26B321F2048IM68-BRTR-ND | EFR32BG26B321F2048IM68-BR |
EFR32FG1V132F32GM48-C0R-ND | EFR32FG1V132F32GM48-C0R |
EFR32FG1V132F64GM32-C0R-ND | EFR32FG1V132F64GM32-C0R |
EFR32FG1V131F32GM48-C0R-ND | EFR32FG1V131F32GM48-C0R |
336-EFR32FG28A010F1024GM48-A-ND | EFR32FG28A010F1024GM48-A |
336-EFR32MG21A010F1024IM32-DRTR-ND | EFR32MG21A010F1024IM32-DR |
EFR32BG1P233F256GM48-C0R-ND | EFR32BG1P233F256GM48-C0R |
336-EFR32MG21A020F768IM32-DRTR-ND | EFR32MG21A020F768IM32-DR |
336-EFR32MG21B020F512IM32-DRTR-ND | EFR32MG21B020F512IM32-DR |
336-EFR32MG24A010F1536IM48-BRTR-ND | EFR32MG24A010F1536IM48-BR |
336-EFR32MG26B211F2048IM68-B-ND | EFR32MG26B211F2048IM68-B |
336-EFR32MG21A020F768IM32-D-ND | EFR32MG21A020F768IM32-D |
336-EFR32MG21B020F512IM32-D-ND | EFR32MG21B020F512IM32-D |
EFR32BG12P232F1024GL125-BR-ND | EFR32BG12P232F1024GL125-BR |
EFR32FG1V132F128GM32-C0R-ND | EFR32FG1V132F128GM32-C0R |
EFR32FG1V132F64GM48-C0R-ND | EFR32FG1V132F64GM48-C0R |
336-3754-ND | EFR32FG1V132F128GM32-C0 |
EFR32FG1V131F128GM32-C0R-ND | EFR32FG1V131F128GM32-C0R |
EFR32FG1V131F64GM48-C0R-ND | EFR32FG1V131F64GM48-C0R |
336-5787-ND | EFR32FG1V032F256GM32-C0 |
336-EFR32MG24B010F1024IM48-BRTR-ND | EFR32MG24B010F1024IM48-BR |
336-EFR32MG24B010F1024IM48-B-ND | EFR32MG24B010F1024IM48-B |
336-EFR32BG26B321F2048IM68-B-ND | EFR32BG26B321F2048IM68-B |
336-5357-ND | EFR32FG1V131F32GM48-C0 |
336-3710-ND | EFR32BG1P233F256GM48-C0 |
336-5101-ND | EFR32BG12P232F512GM68-C |
336-EFR32ZG23A020F512GM40-CRTR-ND | EFR32ZG23A020F512GM40-CR |
336-EFR32MG26B221F2048IM68-BRTR-ND | EFR32MG26B221F2048IM68-BR |
EFR32FG1P131F64GM32-C0R-ND | EFR32FG1P131F64GM32-C0R |
336-EFR32FG28A010F1024GM68-ARTR-ND | EFR32FG28A010F1024GM68-AR |
EFR32FG1P132F64GM32-C0R-ND | EFR32FG1P132F64GM32-C0R |
336-EFR32ZG23A020F512GM48-CRTR-ND | EFR32ZG23A020F512GM48-CR |
336-EFR32ZG23A020F512GM48-C-ND | EFR32ZG23A020F512GM48-C |
EFR32FG1V132F128GM48-C0R-ND | EFR32FG1V132F128GM48-C0R |
