Micron 2GB unable to set WEL bit
Part: MT29F2G01ABAGDWB
I am unable write data because I cannot seem to set the Write Enable Latch in the Feature status register. All SPI signals are verified correct to the datasheet on an oscilloscope. I can read the device ID register and get the correct data reply. The external pins WP# and HOLD# are wired to 3.3V. The CS# pin has a pullup so that it rises with VCC on powerup, as per datasheet.
I set the Write Enable Latch bit according to the datasheet: CS low; 06h (WRITE ENABLE command); CS high; (delay); CS low; FEATURE command for status (1Fh, 0Ch, dummy_byte); CS high. The chip serial out pin goes low and sends 00h at the end of the command. Status and all other Feature registers also read 00h. I expect 02h for the WEL bit set instead.
Do need to do something before I can set the WEL bit? I cannot find anything else in the datasheet. I have tried two parts.
Hello, welcome to the Techforum! I have reached out to our product specialist about this to help troubleshoot why you are unable to write data to this part. Technical reference number T4646586
I made a typo above, FEATURE command for status (1Fh, 0Ch, dummy_byte)
should be FEATURE command for status (0Fh, 0Ch, dummy_byte).
It is correct in my code. I copy-pasted here from the wrong paragraph of the DS.
I will send the updated request to the Product Specialist.
Solved. My typo in code was 0x0C for status register address. Correct address is 0xC0. Now everything works. Note for others: part ships with all blocks write protected. Bits must be cleared in Feature Block Lock (address 0xA0) to enable writing to address block ranges.
That is awesome. Thank you for letting us know.
