Modern Equivalents
Hi, The items I am looking for are from a Lien Chang power supply AIVP-0017 from an “old” Gateway PC monitor. I appreciate this is an ancient item but would like to get it working again.
rwstanbridge
Thank you for contacting DigiKey , sorry I am not finding anything with those part markings .
Thanks Craig
Thank you Craig
Regards
RWS…
Likely AOD408.
DI030N03D1 looks very similar.
Hi Rick
Thank you for your suggestion and the link to the data sheet. Will have a look at the possibilities. I did post two photos the other was similar but was marked as AOD405 (BH5514).
Thank you again.
RWS…
Same pattern, AOD405. DMP3028LK3Q-13 looks similar.
Thank you Rick, will have a look at your suggestions.
regards
RWS
