Momentary push button switch 12 pin and 6 pin
------Question for SPUJ191500 Please Put your question below------
Hello darrinkenthudson,
The SPUJ191500 switch is a DPDT, so it will have 6 pins to solder into the circuit board.
it is out of a audio receiver.
I tried to share a picture of the two not sure if it posted.
@darrinkenthudson
I am not seeing the images got posted.
When making a post you can drag the image(s) you want into the body of a reply to this post.
@darrinkenthudson
I also found the SPUJ193700 for the 12pin option.
SPUJ193700 Alps Alpine | Switches | DigiKey
does the current/amp/ voltage matter?
@darrinkenthudson
The 3746-MPBS-42H01-F14-ND is an in-stock option.
MPBS-42H01-F14 Knitter-Switch | Switches | DigiKey
Thanks for your help I will check out those options.
