Mosfet equivalent/substitute ASAP
I’m in need of a replacement mosfet. The original is a 2SK2313 and it calls for a alternative part of NTE2920.
From what I’ve found there are a couple mosfets that should work. I’m just not 100% positive.
IRFP048PBF-ND - Seems to be the best replacement
IRFP054NPBF-ND - Also seem like a good substitute
IRFP064NPBF-ND - Also seems like a good substitute
If somebody could confirm if these choices would work I would greatly appreciate it
Thank you for your post.
In this case I would suggest going with our number IRFP048PBF-ND as it seems to match most of the ratings of the original part the closest.
Hello @bigjoncoop,
Regretfully NTE is no longer ins business as seen in the LinkedIn announcement:
Out of curiosity, what is the application for your MOSFET.
Best wishes,
