Mosfet for laptop motherboard?
Hello. Can you tell me if you have a Mosfets # SM3308N and SM3319 or acceptable substitutes for these? I tried search but couldn’t find them. Thanks!
Hi @bogart219 ,
Attached are the datasheets.
Cheers, heke
ds-2.pdf (277.2 KB)
ds-3.pdf (140.7 KB)
Hi heke. I had the data sheets, that is not what I asked.Does DigiKey have these? Read the original question.
Hi @bogart219 ,
OK, sorry, just tried to help.
Cheers, heke
No problem, thanks ! I thought you worked for DigiKey.
Hello bogart219,
I’m sorry, but DigiKey does not carry the SM3308N or SM3319 part numbers.
Possible alternate for the SM3308N, is part number 3757-PJQ4548P-AU_R2_002A1CT-ND.
Please check the datasheet for compatibility to your application.
Checking for the next one.
Hello bogart219,
If the SM3319 is also an N-Channel, a possible alternate is part number 3757-PJQ4414P_R2_00001CT-ND.
Again, remember to check the datasheet to verify compatibility.
Thanks Dave!
