Can I get some help identifying this Mosfet, it is on a Miniforums computer model number UM690 the only identifier on them is 8031, the power supply provides 19V and 6.3A the only reference to 8031 is to the Toshiba TPCA8031-H but the packaging doesn’t seem to match, it is around 3.2mm in size. Thank you!
Hello justin.pierson, Welcome to the DigiKey TechForum.
The only other MOSFET out of the 8031 series I could find in our system is TPC8031-H(TE12LQM) which is obsolete but there are listed alternatives at the top of the product page. This one is in the 8-SOP package which has a width of 4.4mm. The dimensions you have seem like an 8-HMST package (3.2mm x 3mm) which we have some options HERE. Please check the datasheet to see if it will work for your application.
