MS3126F-10-6P Pins help
I am building this connector, MS3126F-10-6P, and the pins that came with it are M39029/31-240. They dont fit, they stop as soon as tip start to come out of connector.
Is this the right pin selection, and do you have a build sheet for this conenctor.
Thnx, Steve Sumner
VTG Defense
The parts come as a kit from the supplier. I am looking to see if there is a document available for assembly.
Thnx, it came in a package, heat sealed. These pins just stop, and I have several connectors, and I tried them all…
These are the instructions that I found from Amphenol.
l-786
Figured it out. the pins were correct, but they were very tight. Field pins went in easy as you can push the pin directly, but with a stranded wire, the others were very hard to get in…
