NC SPVQ361600
Hello, i ordered a SPVQ361600 which is Normally open (correct me if im wrong) by default when ordering.
It turned out that i need a a NC version of the switch. Is it possible to order the NC version of the SPVQ361600?
The SPVQ361600 would not be considered Normally Open, it is a Single Pole Single Throw (SPST) and the functions is an On/Off switch.
I don’t see that we have an exact version of that in Normally Closed.
There is a Double Pole Single Throw DPST-NO/NC but the wires come out the bottom of the switch, I don’t know if that would fit in your application. You could just wire up the NC side of the switch.
SPVQ361200 Alps Alpine | Limit Switches | DigiKey
Thanks for the reply kristof.
I need the exact model for a very specific mount. I see on alps website that the switch is made to order for a Normally closed circuit or Off - On.
Right side is the switch i need. left is the one i bought from you guys.
Markings on the right are 16DN ALPS C
