------Question for 59143-1-T-05-A Please Put your question below------
I need to if this swith is normally open or normally closed with the magnet next to it
Welcome to the DigiKey TechForum. The normal state of this switch is open and it will close with the magnet next to it.
Thank you. Do you know if you have that type of reed switch normally closed?
Just changing the parameter from SPST-NO to SPST-NC will provide you with these options.
